im having a problem with a gas leak where it seems to be leaking by the wire feeder . i swapped out the o rings thinking maybe it was getting out through there but it seems to be coming from this portion of the wire feeder. sorry i dont have the words. but ive highlighted it in this picture i found on the interwebs. im not losing gas pressure though the tank or anything like that. a tiny bit of the gas will flow through the gun (where it meant to) but you can hear it all escaping and you can feel it coming out of that hole that is circled on the picture. anyone experienced something like this ///anyone have any bright ideas on how to fix this. this week this has happened to me twice the first time it was the o rings and that solved it for half an hour than it went back to leaking . it does not seem to be leaking through the o rings this time it seems to be dumping out the back end where the wire feeds.
sorry if this is dumb im a stupid newb and im using someone elses machine and i just want to fix this goddamn thing so i can go on with my life. anything helps
