Page 1 of 3 123 LastLast
Results 1 to 25 of 71
Thread: Trouble with Titanium MIG
    Aug 2022
    Hello,
    I am new to the forum. I did post in the new member forum. I am a hobbyist welder working on automotive projects - sheet metal, frames, axle housings. I am not a pro by any means, but I have a moderate amount of experience.
    7 months ago I upgraded(?) to a Titanium Multi Process welder from Harbor Freight. It is currently setup with 0.025 wire, 75/25 gas, and 120V. I had the welder dialed in to where I liked it for 18 gauge sheet metal, but now I am having an absolutely terrible time with burn back. Every single time I pull the trigger, the wire burns back. It is completely unusable.
    This issue started after I welded thicker material with 0.035" wire. I had no issues welding the thicker material, but after I swapped back to the 0.025" wire/settings, I started having this issue.
    These are things I've tried:
    -Gone back to chart recommendations for sheet metal
    -Gone to extreme ends of each: wire speed, voltage, inductance
    -Went through the spool setup procedure. Wire feeds well.
    -Checked all connections.
    -2000psi, 25 CFM
    -Tried a 0.030 tip w/ 0.025 wire
    -Disassembled torch, inspected and cleaned everything
    I have no idea what else to do. In the middle of some big projects and this is very frustrating. I would appreciate any advice.
    Thank you.
  2. Likes NotaVegetarian liked this post
  3. #2
    Aug 2022
    Re: Trouble with Titanium MIG
    To correct my initial post: It was 0.030" that I had swapped to temporarily for the thicker material (not 0.035 like I originally said, can't seem to find edit button).
    I just now swapped to 0.030" again to see what would happen. I can weld without burnback, but 0.030" is not ideal for my project. I am working with 18 and 16 gauge material. Hell, I should have stuck with my flux core. I'm sure I can dial it in a little better, but I would like to go back to the 0.025.
    Brethren, Mi
    I dont know the specifics of this machine but I bet someone comes along soon that does. They are selling quite a few.
    Brethren, Mi
    Obviously depending on several things so this is a generalization but 18 and 16 well within the parameters of 030 to get past a job while you fuss with the machine. I got a Lincoln 255 acts the same way, bump it and runs different.
  6. #5
    It is usually feed too slow or welding up too close.
    Aside from that a feed issue maybe too much spool tension or wire not tight enough in feeder.
  7. Likes Garandman liked this post
  8. #6
    CT
    did you change the drive rollers back to the proper set for the 0.025 wire? Burnback like that sounds like the wire is slipping.
    Miller Multimatic 255
  9. Likes NotaVegetarian, wb4rt, N2 Welding, 455dan liked this post
  10. #7
    Aug 2022
    Thanks for the responses.
    Yes, I do have the roller installed correctly for the wire. It is feeding well.
    I have played around with the feed and the tension on the wire without success.
    When I first got the welder 7 months ago I had to spend some time adjusting the feed (the chart has it way too low in my opinion) so I am familiar with how it is "supposed" to react. It just doesn't anymore.
    Many times since I've had this welder I have been too close or far from the material at times, resulting in burn back or welding the tip. But it used to be that I would simply pull the wire out and move on, no problem. Now it just doesn't give a crap how far/close I am, it burns back every time.
    Yeah, I will work on dialing it in. I just have burning through the 18 gauge, and then there's a lot more grinding.
    Funny you should mention about bumping your welder and having it run differently. I have noticed this about my welder. It has always been the case that it will randomly run differently without me ever touching any setting. I'll get more burn back or can't get a weld started. I just have to walk away.
  11. #8
    Jan 2022
    Sugarland, GA
    Man listen to these folks th3y know what they are talking about
    Retired Old Guy
    Hobart 210
    Lincoln AC/DC 225/125
    Evolution 14 Saw
  12. Likes Locust liked this post
  13. #9
    Aug 2022
    Do you all have recommendations for settings? For either 0.030 or 0.025. I think I will finish my present task at 0.030 because I can at least get somewhere.
    I'm currently welding 16ga patch to 18 gauge sheet metal. Chart suggests:
    Wire feed 145
    Voltage 16.5
    Inductance 3-5
    20-30 CFH
    I have not found the chart to be very useful. I find that the wire speed is way too slow, but maybe I'm wrong. Before this issue I had been running at ~225 for speed.
    Since this issue started, the closest I've come to welding with 0.025 is on a flat piece of 16ga (not making a joint). The "sizzling bacon" sounds like too high of a frequency and it feels like it's trying to burn back. Then sometimes it turns into a mini blow torch.
  14. #10
    NW New Jersey
    Checked polarity ? Wire run-in ? Did any of the gun assembly come loose ? Maybe do a few wire speed checks (count to 6 with trigger pressed, measure multiply by ten) 3 tries should be within an inch of each other. Is the machine still under warranty ? Maybe call the company for Tech support. If the settings worked before the should work again, if not use the support and hold them to the warranty. They will likely ask you some of these same questions, and might better help you as they have a specific list of tests for that machine. They also have a better knowledge of the possible defects specific to that unit. A quick browse through reviews shows a few feed problems, seems like most were resolved by customer service.
    good luck
    Miller Synchrowave 180 sd
    Miller Econo Twin HF
    Lincoln 210 MP
    Dayton 225 ac/dc
    Victor torches
    Snap-On YA-212
    Lotos Cut60D
    Primeweld 225 ac/dc
    Primeweld mig180
    Miller AEAD-200
  15. #11
    Jan 2022
    Which model Titanium do you have?
  16. #12
    Mar 2015
    usa
    i hate to be the one to say it but when you buy nearly the cheapest welder on the planet you set yourself up for alot of greif. theres a reason why good welders cost 10x more. you can all but bet your life they work perfect everytime
    invertig 221 water cooled
    hypertherm powermax 30xp
    fronius transpocket 180
    fronius transsteel 2200
    fronius iwave 230i water cooled
  17. #13
    Apr 2016
    CA
    Pull the nozzle and tip and see if the machine feeds wire. Sounds like a wire feeding issue as Louie suggested with drive rollers. If it welds with .030, I see no reason it shoudn’t be able to weld with .025
    if it feeds ok with out the tip try using a new or different tip.
  18. Likes Louie1961 liked this post
  19. #14
    CT
    Quote Originally Posted by cornchip View Post
    That's nonsense. I am not going to say its the best welder in the world, but of the cheap welders it does a good job, and there have been a number of decent reviews compared the cheaper brands found on Amazon for instance. To me, if it welded fine with 0.025 wire, and it welds fine with 0.030 wire, and the only thing that has changed is the wire, then it is most likely in my opinion that in the process of changing from 0.025 wire to 0.030 wire, the OP changed something and didn't change it back when he went back to the smaller wire.
  20. Likes Garandman liked this post
  21. #15
    Apr 2016
    CA
    spot on.
  22. Likes Oscar, CAVEMANN liked this post
  23. #16
    Dec 2020
    Virginia, USA
    spot on.
    "Spot on, mate!"
  24. #17
    Aug 2022
    Thanks again for all of the responses. This afternoon I did about 1 foot of patch panel on 18/16 gauge with 0.030 with no burn back. I did butt welding with spot welds the whole way.
    Yes, the polarity is correct.
    There is not a run in adjustment on this machine.
    I did your wire feed test with a timer, and it was consistent over 3 tries. However, I did this with 0.030" wire because that is what I am currently set up with. I will certainly try this with the 0.025 wire. I hope to swap back to that later this week. I checked wire tension according to the manual by running wire into a block of wood and seeing if it bends at 2-3", which it does.
    I disassembled the gun and checked tightness of all connections. None were loose.
    It is the Titanium 200 multi process.
    Perhaps this is the case. I do not have side by side experience between this and a welder with the same features made by a name brand. But I spent a lot of time reading reviews and agonizing over going with a Harbor Freight welder. I simply could not find any bad reviews on this one or any justification for spending 2X more for a Miller/Lincoln which had all jumped in price by ~50% between 2019 and 2020. I felt like I would have been paying for a name/sticker. If this is a garbage welder, so be it. But I don't see the evidence of that in reviews/forums.
    It does feed wire without the tip. I have tried new tips but get immediate burn back on the first attempt. However, I have successfully welded this afternoon with 0.030" with no issue. I agree that if it doesn't have issue with 0.030 that I should be able to dial in 0.025.
  25. Likes N2 Welding liked this post
  26. #18
    Oct 2016
    Quote Originally Posted by Locust View Post
    THAT is what finally prompted me to buy a new HTP MIG, funny thing happened all the weird inconsistencies STOPPED.
    I did have a problem with Si bronze but that was "self inflicted".
    It was not as inexpensive as some others, but I think it was money well spent.
    I do have to agree that if you can get .030 to run nicely something is probably being missed. maybe try a different brand of tips and wire.
    HTP Pro Pulse 220 MTS (Anniversary Edition)
    1962 Idealarc TIG 300 300
    1974 Idealarc TIG 300 300
    1988 HF Power MIG 150
    2015 Lotos Ltpdc2000d plasma/Stick/TIG
    Victor 100 torch, 200- 210 Oxy/Acet gauges
  27. #19
    Apr 2016
    CA
    I'd try the .025 wire with a .030 tip! The .025 tips you have might be for .023 or .024. Either way try the next size up aka .030 and see if that solves the proplem. If so it's a feeding issue because of tips.
    Another thing while you are at it with .025 spooled in the machine is to time & measure the wire run out with out a tip installed. Need to know for sure the drive rollers and anything else along the way to the tip is not the problem.
    It's not rocket science but once you understand all the factors that come into play with wire feeding welders, it makes it easier to get to the bottom of what's causing the problems.
  28. #20
    Mar 2015
    usa
    if a guy needs a one time use machine to weld his barn door back on then sure it makes sense but otherwise i think your better off spending a bit more on something you can rely on for years. but thats just my way off thinking. carry on
  29. #21
    Apr 2016
    CA
    What is your contribution to this forum? Do you have how to post's or showed your abilities other than to talk trash about welders because it was purchased at a lower price point. So many things are built in china these days that it makes me sad to think there are no real Americans trying to one up any global welding equipment manufactures. We have the education shops capable of teaching but it seems those places are all infected with simpleton idealism's and changing this world through Plandemic ways of the likes of George Soros and so on. I much prefer George Strait as he's so much easier to listen to and understand the logic in his words.
    Any way back at what you are preaching. Can you afford to buy what you are preaching. If so good for you. For others wanting to learn to do things on a "BUDGET" I see nothing wrong with using a cheap or cost effective product. GTFOH with that $hit! Oh I feel a ban coming. Sorry I call it like I see it!... Thinking of John T at this very moment.
  30. Likes Podman, montero1dfw liked this post
  31. #22
    Oct 2016
    On trying the .030 Tip right but, but re reading his 1st post.
  32. #23
    Apr 2016
    CA
    Quote Originally Posted by 455dan View Post
    I read it all to make sure I was aware perhaps I missed something and you can shed some light on the subject?
  33. #24
    Aug 2022
    And I was trying to put a lot of weight into "Made in the USA" during my purchasing, but I could find no straight answer on whether comparable welders made by American brands are actually made in the USA. Again, I felt like I would have been paying 2X more for a name. "Made in USA" is important, but I am not a charity and inflation is out of control.
    I did try an 0.030 tip with the 0.025 wire. And before I had this issue, I did a fair amount of welding like this when I ran out of 0.025 tips.
    I just wish I knew what it is that I am missing. My plan is to finish what I am working on now with 0.030 wire, and then go back to 0.025 to see if I can figure it out. Maybe later this week.
  34. #25
    Brethren, Mi
    If it was still 2x, this is what is different that 10 years, maybe 15 ago. Import knockoffs were junk and 1/2 the cost, made it a risky bet but now they have got way better even good and are at 20%, some even less. Wish they had this when I was a sprout, everything wass painfully expensive sold only at dealers which was a crap shoot all its own.
Page generated in 1,664,614,642.21611 seconds with 12 queries
