Results 51 to 75 of 91
Thread: Problem drilling mild steel flat bar
  1. #51
    Re: Problem drilling mild steel flat bar
    Slow and lots of pressure and some oil.
    You just finally wore your bit out and then spun it without making chips.
    If ever you are not making chips you must stop quickly or you will do what happened.
    If that bit spins on the work with pressure applied but not cutting it will as mentioned already will work harden the metal right under the bit. A new fresh bit will usually get you back through with extra pressure and a slow speed until that hardened layer has been cut out then it will drill like normal again.
  2. Likes Flyer58, whtbaron liked this post
  3. #52
    Jan 2020
    Magnolia, TX
    So much to learn about something I took for granted and never even thought about.
    My first grinding attempt was almost close, not hand grenade close, but at least I can see what I did.
    I found my chisel angle was close to 90 degrees and not the 135 they recommend which means the relief behind the cutting edge was too shallow. I should have held the bit higher on the curve of the wheel and not low and straight into the grinding wheel center.
    Good PDF listing all the bit parts and angles. Thanks again for leading me in the right direction.
    http://www.neme-s.org/2005%20May%20Meeting/drills.pdf
    Old Lincoln Weld-Pak 100 MIG conversion
    Vulcan 220 Omnipro
  5. #53
    Ideally the cutting lips of the drill bit should be the same length. As close to exactly the same length as possible. Again ideally, it should be forming a shaving from both lips. If they are not the drill may drill oversize except for a short distance as it breaks though the bottom side of the plate. Some unscrupulous machinists may have used this phenomenon to drill oversized holes for relief for fasteners because they did not have the proper sized drill so they would only have to file out a thin section at the bottom of the hole to let bolts go in easily. This are examples of a devise to check angle and length of the lips.
    https://www.amazon.com/Drill-Gage-De...%2C201&sr=8-10
    https://www.amazon.com/PURPOSE-Protr...s%2C201&sr=8-9
    ---Meltedmetal
  6. Likes whtbaron, Flyer58 liked this post
  7. #54
    Quote Originally Posted by Flyer58 View Post
    A stationary belt grinder works well also. It will grind way cooler but I would still quench the drill bit to cool.
    A cheap unit typically designed for woodworking would most likely work as well as an expensive unit.
  8. Likes Flyer58 liked this post
  9. #55
    My belt sander has the disc on the side that I have used for small bits as well, but mostly I just use the finest grit on the grinder wheels. Coarse grits leave a rough surface, cut the metal away very quickly and heat the bit up, I prefer fine grits and very quick light applications of the bit. If you are seeing color change in the metal you are heating up the cutting edge too much.
    Cut 50 Plasma
  10. Likes Flyer58 liked this post
  11. #56
    i've had this for 55 years ...
    it works really well for those lacking good hand to eye coordination
    the plan is to mount it permanently on a small fine grit belt sand for quick touch ups.
  12. Likes Flyer58, whtbaron liked this post
  13. #57
    I've got one like that too... that's what taught me what angles to hold them at...
    Cut 50 Plasma
  14. Likes Flyer58 liked this post
  15. #58
    I have wonder if worked
    Thank you for clearing that up.
    Even today I just use 6" grinder and off hand down to 1/16" and upto 2 ˝,"
  16. Likes Flyer58 liked this post
  17. #59
    anything 3/16” and under I throw away.
    not only am I not skilled enough to hand sharpen the smaller sizes but it’s just cheaper and more efficient to buy extras and have them on hand.
    doesn’t make sense to spend $2-3 of shop time to sharpen a $1 bit (unless of course it’s the only one you have )
  18. Likes Flyer58, Roert42 liked this post
  19. #60
    I to probably would throw away but big number of bits. Today a drill bit last a long time ⌛ as I am only using the drill bit.
  20. #61
    Jan 2020
    Magnolia, TX
    The camera doesn't lie. Here's my second attempt and I may have the chisel angle close and the cutting edges are equal length but looks like they're not straight and a rough cut based on the scoring. I'll blame the grinding wheel The 118 deg angle is also close. The relief behind the cutting edge - oh well...
    I'm the new guy here so I'm open to all questions, comments and verbal abuse. I have the day off so I'm having fun trying.
    you may want to close your eyes Cheers!
    Vulcan 220 Omnipro
  21. #62
    I hand sharpen larger bits in pinch. Larger bits are easier to sharpen well enough to get back in service. Hand sharpening is definitely fasted than a drill doctor. I had a drill doctor for years. It will give consistent finish, however. But, It was faster and economical to just buy new smaller bits.
  22. Likes Flyer58 liked this post
  23. #63
    It does look in even, however a side view will show if the profile is close. It the relief is not correct the the edges will not contact the material… No drilling.
  24. Likes Flyer58 liked this post
  25. #64
    Jan 2020
    Magnolia, TX
    The primary relief looks good. It's my understanding the relief angle is what determines the chisel point angle - looking for the 135deg. I tried adding a secondary and steeper relief a little behind the primary relief. I think the Drill Doctor just rounds it down after the cutting edge.
    Vulcan 220 Omnipro
  26. #65
    It doesn’t look even. Correction
  27. Likes Flyer58 liked this post
  28. #66
    Jan 2020
    Magnolia, TX
    There's a lot that still not right but the camera gives me an idea what's happening.
    Better than my eyes.
    Vulcan 220 Omnipro
  29. #67
    Mar 2015
    I must have unwittingly bought some fine bits or am just lucky. More than 40 yeras ago I bought a set of bits from a hardware store and only replaced those I broke or lost. The index says Hanson. Due to vision problem I have to use a jig to sharpen but despite several sahrpenings the bits still make curled ribbons. If a bit doesn't start cutting right away I stop and regroup. I think most people here have witnessed ho quick an abrasive cut off wheel can work harden and stop cutting. It's the same with drilling,it doesn't have to spin long before bit and work overheat and harden. My grandson thought I was being silly when I told him to dip the bit after every hole he was drilling in a new trailer floor but he was impressed after the same bit drilled all the holes without resharpen.
  30. Likes Flyer58, whtbaron liked this post
  31. #68
    Dec 2020
    Virginia, USA
    I resharpen EVERYTHING. Being able to touch up a 1/16" bit is actually pretty helpful.
    I tend to change tip angles, bevel sizes, etc. Based on material. Only takes a second with a bench grinder.
    I just save up all my dull drills and sharpen them as a batch.
    With a 1/8" or smaller drill, I might "rough in" the point with the grinder, then give it a lick or two with a bench stone. I usually just use the grinder, though...
  32. Likes Flyer58, whtbaron liked this post
  33. #69
    Laredo, Tx
    But can you sharpen a 3-flute cobalt drill bit with all the relief angles?!?
  34. Likes Flyer58 liked this post
  35. #70
    Jan 2011
    W. Wisc
    Still too much land behind the cutting edges. You want it to look more like the pic below where you remove the parts circled in red. Then you want more relief on the part farthest away from the edge. Otherwise you have a very hard time making chips as it requires a lot of pressure to get the edge to bite. Not enough relief.
    Myself, I will sharpen down to about 1/4" and then it is too hard to do for me. Fine wheel on an 8" bench grinder. I often find I have to come back and add more relief to the bit, so I am very familiar with that part of it...
    Name:  Screenshot - 8_6_2022 , 9_02_33 PM.jpg
    -Dave
  36. Likes 12V71, Flyer58 liked this post
  37. #71
    Jun 2017
    AJO, ARIZONA
    My wife bought me a couple of Chinese drill bit sets years ago, it was obvious out of the gate that they were junk & wouldn't drill anything but soft wood. Closer inspection revealed that they were sharpened backwards, the heel of the bits were higher than the leading edge, after resharpening they were almost halfa$$ed decent, I think I ended up giving them away.
    NRA LIFE MEMBER
    UNITWELD 175 AMP 3 IN1 DC
    MIDSTATES 300 AMP AC MACHINE
    LET'S GO BRANDON!
    "Those who would give up essential Liberty, to purchase a little temporary Safety, deserve neither Liberty nor Safety.” BENJAMIN FRANKLIN
  38. Likes Flyer58 liked this post
  39. #72
    You do realize that these kind of bits, with the 3 flutes, were originally designed to widen holes. It's very hard to find them anymore. I'd like to have a decent set of the diameters I work with the most.
    And..........."cobalt" is just a sales gimick to sell HSS. Sorta like Titanium, or other coatings/additives. In the end, it's the sharpened HSS cutting edge that does the work.
    Regular HSS, off the shelf, is plenty hard to drill anything but steel that's harder than HSS. Provided it's kept sharp.
    The relief angle is key to the deal. The sharper the angle, the better it cuts. It will actually suck its way down into the steel. Kind of like a plow. On the flip side, the cutting edge will decay much faster. But if you have a bench grinder, it's not an issue. Takes about 3 minutes to sharpen a bit. I came to this the hard way. I got tired of throwing out bits when they got dull. Found that the drill bit sharpening machines are mostly junk.....................bought a General Hardware drill bit gauge, and never looked back. You can virtually get a lifetime out of most any drill bit, if you learn to sharpen it freehand.
  40. Likes Flyer58 liked this post
  41. #73
    Does anybody dress their grinding wheel. The nastiest operation in the shop.
  42. Likes Flyer58 liked this post
  43. #74
    Dec 2020
    Virginia, USA
    Ehhhh... that's not entirely true. Titanium nitride, aluminum titanium nitride, and other coatings like that can make a huge difference in a production environment. Especially on a CNC machine.
    They let you run high feeds and speeds.
    With a hand held drill or a drill press, it'd not really worth it.
  44. Likes Flyer58, CAVEMANN liked this post
  45. #75
    Dec 2020
    Virginia, USA
    Well... guess there's one way to find out! You go ahead and buy me a set of them, I'll use them till they're dull, then try and sharpen em.
    I prolly could touch one up if I was in a pinch. I've turned regular drills into split points with a sharp corner on a bench grinder and a set if diamond files.
    Look up "hyper step" drills. It's a twist drill, but the point is ground in steps (like a normal step drill). They're supposed to be pretty great.
    Actually, here's a link to some. Apparently "hyper step" is just a sorts generic term for them.
    https://www.amazon.com/Norseman-2290...77678630&psc=1
  46. Likes Flyer58 liked this post
Page generated in 1,664,116,975.11871 seconds with 13 queries
