Results 1 to 25 of 42
Thread: Hearing protection while welding?
    May 2021
    Southern California
    I received an email from Miller today. In the email, there was a picture showing a welder (weldor) wearing ear plug hearing protection.
    Name:  Ear Protection.JPG
    This got me thinking. Hearing what the weld is doing is important to me. Short circuit, I want to hear a specific "crinkle" (some call it frying bacon, but it sounds different to me) For spray, I want to hear the transition to a quiet "hiss".
    Sure, I am looking at the weld, but the sound is giving me a confirmation also.
    Maybe this should have been in the Safety forum, but I thought I would get better visibility here(?)
    I also get that maybe the operator in the picture was just grinding on something...
    The question is, do others rely on hearing the weld as much as I do? Do you wear haring protection for welding?
    Thanks for the input.
    Geoff
    Laredo, Tx
    Re: Hearing protection while welding?
    I still wear earplugs because they do not block 100% of sound, nothing does. So I can still hear everything, just at a lower decibel level and that is enough for me.
  3. Likes 52 Ford, ToolFanGeoff liked this post
    Fredericksburg, VA
    I pretty much put ear plugs in as soon as I go out into the shop. The time I spend using grinders, saws, hammering and using tools generally more than the actual welding.
    Plus when TIG welding, it is virtually noise free except for when doing aluminum.
    Millermatic 252 MIG
    Miller Dynasty 200DX TIG
    Miller Spectrum 625 Plasma
    Altas 12x36 Metal Lathe
    Bridgeport Milling Machine
    www.psacustomcreations.com
  5. Likes 12V71, ToolFanGeoff liked this post
  6. #4
    Fredericksburg, VA
    Willie's post the othe day is typical for me.
    I am adlibbing his post but 4 hours of work to do 15 minutes of arc time is not far fetched
    Millermatic 252 MIG
  7. Likes ToolFanGeoff liked this post
  8. #5
    similar for me too
    4 hours blank stare and head scratching / 5-10 minutes arc time / lunch
  9. Likes 12V71, 52 Ford, ToolFanGeoff liked this post
  10. #6
    Jul 2022
    Virginia
    Here’s the real question…..does arc welding on a regular basis produce enough sound to damage hearing? Has anyone measured the decible levels? It is obvious that grinding with a handheld grinder produces both decibel and frequency ranges that will be harmful, not to mention most saws like a portaband, cut off saw, etc. Just for the arc welding, I am more concerned about damage to lungs/sinuses because of fumes than the issues with hearing from just running a bead/beads on an average project.
    Miller Multimatic 215
    Spoolmatic 150 spool gun, Miller TIG kit
    Primeweld Cut 60 Plasma Cutter
    Vevor Pipe Stands
    Bauer Portaband/Swag table
    Grinders-Milwaukee, Porter Cable, Dewalt
    ArcUnion M-20 portable rod oven
  11. Likes ToolFanGeoff liked this post
  12. #7
    Only reason I can see for wearing the earplugs while welding would be to keep hot berries from getting in there. I've been using a headset/face screen for the grinding and beating part (although the screen still requires safety glasses during grinding) and I'm kind of getting to like it.... almost... much quieter...
    Cut 50 Plasma
  13. Likes ToolFanGeoff liked this post
  14. #8
    Mount Tabor VT
    Ever had a molten BB roll into your ear canal while you have your hear turned?
    Ear plugs reduce the damage of you, or someone else in the area grinding.
    Extremely loud industrial noise, then someone feels the need to make idle conversation, I can better sort human voice with ear plugs.
    Had I used ear plugs 50+ years ago, I bet I wouldn't have hearing loss now. I remember Lee Sonic Ear Valves. I bought a set for shooting at maybe age 13. They were supposed to react to loud noise but not restrict ordinary sound. They absolutely did NOT work. Aside from that, I never heard of hearing protection until age 30. I can't estimate how many rounds of ammo, chainsaws, cutting tools, grinders, motorcycles, snowmobiles. Let's not forget rock music!
    By the way, I'm NOT buying you can't hear sizzle with hearing protection. That, I call BS. With hearing loss & hearing protection, today I was thinking how satisfying the sound of a fresh roll of wire.
  15. Likes ToolFanGeoff liked this post
  16. #9
    only reason i can see for wearing the earplugs while welding would be to keep hot berries from getting in there. I've been using a headset/face screen for the grinding and beating part (although the screen still requires safety glasses during grinding) and i'm kind of getting to like it.... Almost... Much quieter...
    ^^^^^this^^^^^
  17. Likes ToolFanGeoff liked this post
  18. #10
    and ^^^^THIS TOO^^^^
    didn't want wille to feel left out
  19. Likes whtbaron, ToolFanGeoff liked this post
  20. #11
    May 2021
    Landrum, SC
    I protect my ears with music. No buds or earphones tho.
    Now when I have to grind (a lot) I'll wear these.
    Lincoln 330MPX
    Lincoln Power Mig 256
    Lincoln LN-25X Wire Feeder
    Magnum PRO 250LX GT Spool Gun
    Lincoln AC/DC 225
    Ton of Torches OFC-A OFG-A
    Air Carbon Arc Gouging
    CAC-A
    Everlast 62i Plasma Cutter
    Ingersoll Rand T-30 14hp
    Instagram: #Freebird Welds
  21. Likes ToolFanGeoff liked this post
  22. #12
    Quote Originally Posted by Freebirdwelds View Post
    i'm not posting a pic of my set. i'm
    assuming yours look like mine and others will question our sanity when they see how gross they look.
  23. Likes ToolFanGeoff liked this post
  24. #13
    Mount Tabor VT
    Standard getting dressed in the morning is a pair of loose earplugs in my pocket. They get nasty often. Between phone calls, I leave them in. I toss them when they look grubby, usually because my hands get grubby.
  25. Likes ToolFanGeoff liked this post
  26. #14
    May 2021
    Landrum, SC
    Well I do have 2 pairs hanging in the cabinet in the truck. Really doesn't help when grabbing the cleanest pair when you need them.
    But letting them get rained on does help. lol
    Lincoln 330MPX
    Lincoln AC/DC 225
    CAC-A
  27. Likes ToolFanGeoff liked this post
  28. #15
    Jan 2022
    Sugarland, GA
    Used ear plugs always in noise hazard areas an$ I’m still deaf, now have hearing aids in both ears. Long term exposure to hazardous noise above 128 decibels is harmful even with hearing protection
    Retired Old Guy
    Hobart 210
    Lincoln AC/DC 225/125
    Evolution 14 Saw
  29. Likes Freebirdwelds, Roert42, ToolFanGeoff liked this post
  30. #16
    i snapped a pic of mine anyways. they don't look as bad as i thought....
    IMAGE CHANGED TO LINK TO ADULT CONTENT
  31. Likes 52 Ford, Roert42, ToolFanGeoff liked this post
  32. #17
    Yea.... gross earplugs can be a chronic condition. I cure it by just having a clean tissue in my pocket and using chunks of that. Works, but probably not the best for dingleberry protection ...
    Cut 50 Plasma
  33. Likes ToolFanGeoff liked this post
  34. #18
    LOL.... not gross at all..... heavy hauling or heavy breathing??
    Cut 50 Plasma
  35. Likes 52 Ford, Roert42, ToolFanGeoff liked this post
  36. #19
    Apr 2022
    Quote Originally Posted by RCWelds View Post
    Earplugs for a Portaband? Really? You must have some delicate ears!
  37. Likes Lis2323, ToolFanGeoff liked this post
  38. #20
    I was thinking the same thing 🤔.
    Quote Originally Posted by StandarDyne View Post
  39. Likes ToolFanGeoff liked this post
  40. #21
    May 2021
    Landrum, SC
    Yeah, without a doubt yours hang much nicer than mine. I'm going to have to rethink my whole hanging system on the truck now. Name:  sigpic67943_5.gif
    Last edited by Tensaiteki; 08-05-2022 at 12:05 AM. Reason: quoted image changed to link
    Lincoln 330MPX
    Lincoln AC/DC 225
    CAC-A
  41. Likes whtbaron, ToolFanGeoff liked this post
  42. #22
    May 2021
    Landrum, SC
    Wait what were we talking about again?
    Lincoln 330MPX
    Lincoln AC/DC 225
    CAC-A
  43. Likes Lis2323, Flyer58, ToolFanGeoff liked this post
  44. #23
    The calendar 📅.
  45. Likes ToolFanGeoff liked this post
  46. #24
    Aug 2019
    northeastern PA.
    racing boats, airplanes, rebuilding diesel engines and grinding all lead to WHAAAAT !!!
  47. Likes ToolFanGeoff liked this post
  48. #25
    Sep 2016
    Detroit, Michigan
    My family has a history of hearing loss on my father's side, and since I grew up as a competitive shooter, flying airplanes, in the military, etc I learned to be careful of my hearing early on. I have a bit of tinnitus, that I'm pretty sure came from one event when I was in the military...we were training on movement to contact with actual opponents and our guns were all set up for blanks with MILES gear (lasers) and a guy let rip with an M-60 maybe two feet from my head...my ears rang for days. Other than that, my hearing tests for work are always pretty good, so whatever I'm doing is working.
    In the past handful of years they've done some new studies on long-term hearing loss due to noise exposure. One of the things they've found is that the threshold for damage is lower than they used to cite. It's also now a combination of decibels and time, so anything over 70 decibels for a long period of time can cause permanent damage (can, not will). A loud washing machine is 70 decibels. Also, people often don't realize the decibel scale isn't linear...it's logarithmic, so going from 70 to 80 is a huge jump. Your typical law mower is 80-85 dB.
    Plugs are good for most normal sources of noise, but not if there is a pressure element such as shooting a gun. There, the pressure is transmitted to the small bones of your inner ear through the soft tissue just at the back and base of your ears...that soft spot you can push in. Those bones are critical to hearing and they break down from the shock transmitted through the soft tissue. Most law enforcement agencies now require muffs that cover the entire ear for training for that very reason. That's also why so many law enforcement agencies are going to suppressors on their long guns...just a single shot near a partner can cause permanent loss.
    I wear hearing protection during anything loud...diesel tractor, skid steer, zero turn, leaf blower, string trimmer, chainsaws, grinders, saws, and often when I'm welding (especially AC TIG). Heck, even when I really have to hammer on something I'll put on muffs. When I fire up the forge to do some blacksmithing I immediately put on muffs...just the gas forge itself is loud. I'll even use plugs or muffs when I use the shop vac for more than a few seconds.
    My take is that it's all cumulative and if I don't want to be deaf when I'm 75, I need to be taking care of my ears now. I actually find that with many things it helps me concentrate...less noise = less distractions. I often find I've stopped the noisy activity and still have my plugs/muffs on.
    I keep plugs and muffs pretty much everywhere in my shop and vehicles. I recently got some custom molded acrylic plugs that have passive filters and I'm really impressed. I like muffs because they're quicker to put on and off and don't get nasty like foam plugs (well, if they do you can wipe them off easily) so I use those more than plugs.
    When I'm doing something like mowing with the tractor/zero turn or using my skid steer I wear noise cancelling ear protection. That way I am protected, but can hear if someone shouts at me, or if something is wrong like grabbing a piece of wire in the flail mower.
    http://mivise.com
    Hobart Champion Elite
    Everlast PowerTig 210EXT
  49. Likes whtbaron, RCWelds, ToolFanGeoff, bead-boy liked this post
Page generated in 1,664,608,477.46723 seconds with 13 queries
