Results 1 to 18 of 18
Thread: Keeping stock
    Aug 2022
    Los Angeles
    Keeping stock
    Iíve noticed that some welding wire comes packaged in sealed pouches and, since I have wire thatís been on the shelf for over a year, it begs a few questions for me; 1) does exposure to air degrade the integrity of the wire; 2) should I keep my wire in a sealed bag and 3) as only a novice and occasional welder, is there a timeframe for any degradation? Thanks again for any insight.
    Laredo, Tx
    Re: Keeping stock
    It depends on the wire. What is the AWS classification of your wire?
    May 2021
    Landrum, SC
    Re: Keeping stock
    Quote Originally Posted by Bukeroo View Post
    I’ve noticed that some welding wire comes packaged in sealed pouches and, since I have wire that’s been on the shelf for over a year, it begs a few questions for me; 1) does exposure to air degrade the integrity of the wire; 2) should I keep my wire in a sealed bag and 3) as only a novice and occasional welder, is there a timeframe for any degradation? Thanks again for any insight.
    That's a pretty broad question considering the 100's of types of wire out there. For what wire costs, replacement liners and everything in between. You should always do your best to keep your wire dry, clean and free of contaminants. It should be kept in a sealed bag regardless.
    Lincoln 330MPX
    Lincoln Power Mig 256
    Lincoln LN-25X Wire Feeder
    Magnum PRO 250LX GT Spool Gun
    Lincoln AC/DC 225
    ľ Ton of Torches OFC-A OFG-A
    Air Carbon Arc Gouging
    CAC-A
    Everlast 62i Plasma Cutter
    Ingersoll Rand T-30 14hp
    Instagram: #Freebird Welds
    SoCal-LA
    Re: Keeping stock
    In Los Angeles you should not have to worry about moisture. I don't. Just keep it packed, boxed, or in a cabinet.
    Sep 2016
    Detroit, Michigan
    Re: Keeping stock
    For hobby work, if the wire isn't rusty, you're fine.
    http://mivise.com
    Hobart Champion Elite
    Everlast PowerTig 210EXT
    Aug 2022
    Los Angeles
    Re: Keeping stock
    Thank you all for the answers. Right now I just have fluxcore and regular steel for mig and some aluminum that I tried with argon quite unsuccessful in their boxes.
    Aug 2022
    Los Angeles
    Re: Keeping stock
    I have no idea. Just now learning what AWS classifications are and the importance of them.
    SoCal-LA
    Re: Keeping stock
    It only matters if there is a code to adhere to. Otherwise you can weld with coat hangers if you are competent.
  9. Likes N2 Welding liked this post
  10. #9
    Re: Keeping stock
    I have welded with coat hanger and
    propane cutting torch in field. Before I new better. It was 4Ĺ hours back to shop where the welder was sitting and my father ask weld a clip back on that was knocked off in shipping. I was also under 18 at time too.
  11. #10
    Laredo, Tx
    Re: Keeping stock
    This is basically what I wanted to know, what kind of wire you were even talking about.
    Cored wires are the ones that are very susceptible to moisture entrapment, the other wires simply develop surface oxides. Moisture entrapment presents a bigger problem for cored wires than surface oxides on solid wires, since surface oxides can be removed with felt pads and what not.
  12. #11
    May 2007
    Re: Keeping stock
    yeah, its funny how many things worked ok, before we knew better. then when we know better, suddely its a problem. also 4.5 hrs back to shop, if ur dad was like mine, my *** would be grass, for not bringing welder the 1st time
  13. #12
    Re: Keeping stock
    I learned
    Most my fathers work was at less 4 hour drive some work was almost 12 hour of driving. Very little in town when I was growing up.
  14. #13
    Re: Keeping stock
    I have never been on Greyhound buss.
    But I been with my mother at station a lot taking parts and bolts my forgot.
    This was before FedEx or UPS and the US mail would get there someday.
    Greyhound would deliver on next buss.
    I had make clips before putting on Greyhound. This before I could drive.
    My mother take his shop cut clips then take back to home hobby shop and drill holes. I used a lot of cutting oil and sent on Greyhound smell of cutting oil no paint needed.
  15. #14
    Aug 2022
    Los Angeles
    Re: Keeping stock
    We’ll, it was a general question since I’m just now learning about welding and now wire composition. Thanks again for your responses. I’m learning.
  16. #15
    Re: Keeping stock
    The biggest problem with wire is rust will jam the feed.
    My line of work I keep only one to three months supply of wire. This because the type of work I did at any time it could be test and people lives could be in danger if a weld failed.
    If doing AG type work it ok to very old wire or rod, avoid rusty wire because of equipment.
  17. #16
    May 2010
    ct.
    Re: Keeping stock
    I threw out half a small roll of flux core after about a year.
    It had gotten a little rust on it and I wasn’t willing to put it
    through my liner. Haven’t had any problem with solid wire
    yet, and I don’t use mig very often. I have one roll that’s
    actually been out of the package for about four years.
    Miller a/c-d/c Thunderbolt XL
    Millermatic 180
    Purox O/A
    Smith Littletorch O/A
  18. #17
    May 2007
    Re: Keeping stock
    I learned
    4 hrs u could still get to sf, w/o heavy traffic. probaably la too. a summer day in sf, alot cooler than fresno
  19. #18
    May 2007
    Re: Keeping stock
    i completely forgot about that. i think i been to greyhound a time or two. when kids, we called the ups truck, the "swat van" . we'd yell "mom, swats here", cuz the tv show swat had a black van like that. while u were working and getting clips at greyhound, i was getting fishing poles w/ my moms grocery blue chip stamps
Page generated in 1,664,635,700.77724 seconds with 12 queries
