Results 1 to 5 of 5
Thread: 6-50R wiring
    Feb 2022
    6-50R wiring
    I am wiring a 6–50R for a Lincoln AC/DC using 6/2. On the receptacle, there is an x y and g label. I know G is for ground but does it matter which wire (white and black) go in the X and Y spot? It would seem that it doesn’t matter, I’m just double checking. Thank you
    Re: 6-50R wiring
    Quote Originally Posted by TooNew View Post
    Yes it matters or the polarity will be wrong !!!! JOKING !!!
    No sir it does not matter. Black in the X and white in the Y.
    It will not make any difference.
    Feb 2022
    Re: 6-50R wiring
    Thank you! Always better to have a second set of eyes on it to double check!
    Mount Tabor VT
    Re: 6-50R wiring
    & to clarify, G is for ground. IT IS NOT FOR NEUTRAL (OR CENTER TAP). If from a sub panel ground & neutral should be separated. If from a SERVICE panel, they MAY be separated, but bonded.
  5. Likes scsmith42 liked this post
  6. #5
    Wink Re: 6-50R wiring
    Very true.
    Since it is Romex and the ground is bare I was pretty sure you knew it went in with other bare and/or green ones in the panel.
    It is not a current carrying conductor. To the equipment ground bar of panel in either case.
    If your MAIN breaker is in the same panel then then ground bar and the neutral are at same potential and could even be sharing on the same bar. In that case if it has them separated in their own bars put it in with the grounds if all sharing pick a hole and land it.
Page generated in 1,713,311,248.30605 seconds with 19 queries
