Results 1 to 24 of 24
Thread: Mag Drill new $210.00
    HF 170 welder
    HF 4x6 band saw
    South Bend 9N
    Mill
    B&D mag drill
    Victor torch
    Laredo + Midland/Odessa
    Re: Mag Drill new $210.00
    Dec 2020
    Virginia, USA
    I win. https://rentaltoolsonline.com/mab-13...8aAnTREALw_wcB
    112 pounds, 220V, 20A, 220*20/745=5.9... 5.9 freaking HP!
  4. Likes Oscar, precivilization, LtBadd liked this post
    Dec 2020
    Virginia, USA
    https://rentaltoolsonline.com/cs-uni...agnet-wide.htm underwater hydraulic mag drill. I like it says "automatic lubrication"... it's an underwater tool...
    Underwater drill... now with flood coolant!
  6. Likes Oscar, precivilization liked this post
  7. #5
    Mar 2017
    Dubai
  8. Likes LtBadd liked this post
  9. #6
    If I was going to buy a cheap Mag drill at this point, I think I would buy this one: https://www.amazon.com/VEVOR-Drill-S...%2C2066&sr=8-9
    More power, lower and variable RPM, larger bit diameter capacity.
    ---Meltedmetal
  10. Likes whtbaron liked this post
  11. #7
    It for any starting in metal work it gets you up and running for low cost .
    My self I have a B&D 3/4" very heavy duty witch I purchased new but most starting may not have funds for a new Dewalt (old nane Black & Decker).
    You or I would buy a name brand but we have been doing for a long time.
  12. #8
    Quote Originally Posted by precivilization View Post
    i really like that
  13. Likes Country Metals liked this post
  14. #9
    Dec 2016
    New Jersey
    Dammit Dave - now I have this on my mind!
    I've been looking for one - used on F.B. and C.L. for some time - not that it's needed (of course) for any particular project although I could use for a go-kart build now - the price seems "right" - and I'm just a hobby hack - name brands are just out of reach for numerous reasons... sheesh - now I'm going to be thinking about this the ENTIRE Holiday weekend - and end up pulling the trigger after 5 or 6 IPA's.....
    A lot of positive reviews for it I'd have to say - from the Amazon website.....of course then I'd have to buy the annular cutter arbour and cutter set for another $140 - I better make that 7 - 8 IPA's.....
  15. Likes whtbaron liked this post
  16. #10
    Dec 2016
    New Jersey
    G-dammit! now there is this one! - in for a penny in for a pound?! what's another Hondo for a tool you don't need and will rarely use?!
  17. Likes whtbaron liked this post
  18. #11
    Quote Originally Posted by jfk92 View Post
    And if you need a regular chuck add this: https://www.amazon.com/Drill-1mm-16m...xpY2s9dHJ1ZQ==
    I almost bought one but I doing renovations and a 360 degree cross beam laser won out in the end with a detector in case I want to use it out side. Canadian $ on this : https://www.amazon.ca/gp/product/B07...?ie=UTF8&psc=1
    ---Meltedmetal
  19. #12
    I don't need one often either... but that's getting tempting...
  20. Likes 12V71, BD1 liked this post
  21. #13
    You find it is very handy tool.
    I have used mind for drilling, drill press, tapping and line boring.
  22. Likes whtbaron, Podman liked this post
  23. #14
    It is a very handy tool.
    I keep mind in retirement.
  24. #15
    Il]
    I “think” while this adapter setup will allow you to use a twist drill you may have to get innovative to put it to use.
    The quill travel on your mag drill will most likely not raise high enough to use as designed.
  25. Likes whtbaron, Meltedmetal liked this post
  26. #16
    I was looking at Precivilization's setup... looks like the bit would be below the surface on a flat job. I wonder who makes the shortest bits? When I get in a tight place I resharpen an old broken bit and use the air right angle drill. Works, but its not much fun...
    Yes, like in post #5.
    ---Meltedmetal
  28. Likes Lis2323 liked this post
  29. #18
    Don't want to take your new Cobalt bits to the chopsaw?
  30. Likes Meltedmetal liked this post
  31. #19
    Back in the day I used to watch a TV show called "Have gun-Will travel."(1957-1963) I have a business card from a cap gun set that was available when I was a kid. It says"Have gun-Will travel. Wire Paladin San Francisco" Maybe I should print my own that say "You have money? We'll help you spend it."
    ---Meltedmetal
  32. Likes whtbaron liked this post
  33. #20
    Mind I only use a standard twice drill bits .
    Never had to cut one, just chuck and drill.
    I had to turn a few drill bits my chuck is 3/4" and I need to drill 1-1/16" [27mm] holes.
    I do not who needs to drill holes 1-1/16" [27mm] holes.
    The holes was on a D8 CAT tractor.
  34. #21
    It happens... my biggest bit is 1 1/4" and it gets used. I was thinking for most machines it would only affect the larger bits...
    If you look close, I don't believe that drill is set up for annular cutters. You have to buy an MT arbor to use annulars. I'd not want that. Morse Taper doesn't handle annular cutter load very good.
  36. Likes Lis2323 liked this post
  37. #23
    I always liked Richard Boone. His best role was in "The Shootist".
  38. #24
    Morse taper is still used on some milling machines.
    It is a drill not a milling machine.
    I do not want you are trying to do with a mag drill?
Page generated in 1,713,292,734.67268 seconds with 19 queries
