Results 1 to 25 of 38
Thread: Black Pipe Frustration
    Aug 2022
    Trying to stick weld a section of ¾” black pipe to a 25lb weight. See photos for set-up. I keep blowing through the pipe without any penetration into the weight. Machine is an ARC-160 set at 160 current & Arc Force of 5. Using E6013, 1/8” rods. Photos added. Newbie, so any suggestion would be helpful.
    Mar 2005
    Under a Rock
    That looks like cast-iron to me.
    I hope you're not trying to make any type of weightlifting equipment
    Even if you do preheat it and get it to stick it will still probably break and fall on your head.
    Sooner or later
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
  3. Likes Roert42, CAVEMANN liked this post
    Jul 2021
    Re: Black Pipe Frustration
    Can you get a puddle going at all on the weight, forgetting about the pipe?
    I would assume the weight is cast, making it hard to weld. If it is you would probably want to use something designed for dissimilar metals or Nickle rod, or braze it with a torch.
    Might just be easier to attach them using some mechanical fasteners. slide the pipe through the weight and put a locking collar on either side so it cant move.
    Airco Auto-Pak 130
    Forney 235AC/DC
    Miller Econo Tig
  5. Likes CAVEMANN liked this post
  6. #4
    May 2010
    Ct.
    Tried to turn a 10 lb.weight in a lathe to try to make a flywheel.It had voids
    and pockets of some sort of dirt.Destroyed cutting tools. Some sort of really
    crude cast iron. Made bed frame angle iron look good by comparison
    Miller a/c-d/c Thunderbolt XL
    Millermatic 180
    Purox O/A
    Smith Littletorch O/A
    Hobart Champion Elite
  7. Likes Roert42 liked this post
  8. #5
    Dec 2015
    Western New York State, USA
    probably cast iron, usually need nickel rod to stick weld. some will braze it with a torch. if weld is brittle a cast iron weld can snap with
    little warning, preheat and slow cooling can help
    usually welding thick to thin, rod points toward and favors the thicker side might weave to thin side quickly just to get puddle to thin part, often
    2/3 to 3/4 of weld puddle on the thick part (where extra heat needed)
    others us a inline weave with bigger rod again favoring thick part, inline weave going forward then backing up some periodically,
    hard to describe, inline weave popular among some pipe welders
    welding thick stuff over 1/2" thick to say thin conduit thats .040" to .060" thick can be difficult. some use dab dab. that is often bigger
    rod running relatively high amp, welding 1/2 to 1 second, stop arc and wait a second or 2, weld another dab, stop, dab, stop, dab
    ....dab dab welding many youtube videos showing .060 and even .040" thick or thin tubing being stick welded. some weld a dab going across joint,
    sort of like a single side weave, stopping arc waiting, thats why called dab dab, a dab of weld at a time pausing each dab. some lean rod
    quite a bit so arc force not as strong. usually got to favor the thicker side to not burn through the thinner side
  9. Likes Roert42 liked this post
  10. #6
    Mar 2005
    Under a Rock
    Quote Originally Posted by jpump5 View Post
    Most of those Olympic weights are made in China.
    It's all the crap metal we send them... stolen shopping carts/manhole covers, hubcaps and ... yep bed frames.
    Hypertherm PM 45
    HTP 221
  11. Likes Roert42 liked this post
  12. #7
    Sooner or later
    what john said^^^^^
    if not for weightlifting can you weld a bracket to the black pipe and attach to the plate weight mechanically ? (bolted or?)
  13. Likes Freebirdwelds, 52 Ford, Roert42 liked this post
  14. #8
    Apr 2022
    I'm with John T and Lis. Probably crap cast iron. No weldie.
    Alternately, you might be able to braze-weld it, but I'm guessing you don't have oxy-acetylene. Got epoxy?
  15. #9
    I am glad you sought advice. If it were the best cast iron, welded with 6013 you would still have potentially disastrous results.
    Good luck
  16. #10
    Jun 2017
    AJO, ARIZONA
    Those molds look like they came out of a copper smelter. I agree, those weights are probably cast iron. Be careful with them if you weld them.
    UNITWELD 175 AMP 3 IN1 DC
    MIDSTATES 300 AMP AC MACHINE
    JEFF
  17. #11
    your photo shows a standard plate weight which would have a nominal 1"D hole.
    you could thread the end of the 1" pipe. and sandwich the plate on it between a big welded washer (with 1" hole " and 1 " NPT "nut"
    or if it's ok for the plate to spin , lock it in position with two set screw shaft collars.
  18. Likes StandarDyne, Roert42 liked this post
  19. #12
    maybe best show us what you wish to accomplish so that someone here can help you best.
  20. #13
    May 2021
    Landrum, SC
    Quote Originally Posted by blocks5757 View Post
    This man Lis has fabricated tons of gym equipment. It may be wise to heed his advice if that is what your trying to accomplish.
    If you trying to make stands, he probably can help you with that also.
    Lincoln 330MPX
    Lincoln Power Mig 256
    Lincoln LN-25X Wire Feeder
    Lincoln AC/DC 225
    ¼ Ton of Torches OFC-A/OFG-A
    Air Carbon Arc Gouging
    CAC-A
    Lincoln Tomahawk 1000
    Ingersoll Rand T-30-14hp-25cfm
    Instagram: #Freebird Welds
  21. #14
    Aug 2012
    AR
    On top of all this, 6013 is a low penetration rod, and for 1/8" electrodes 160 amps is way too hot...no wonder you are blowing holes. Normal amps for 1/8" rods should be in, say, the 100-120 amp range, some may say even lower. That being said, all the other comments are warning you away from making a dangerous project out of this.
  22. Likes metalmeltr liked this post
  23. #15
    As everyone mentioned, probably cast iron. Use a bolt and washer for the top and nut and washer for bottom. Pipe will fit over the bolt head and weld to washer.
    If bottom needs to be flush, cut bolt thread, add washer and plug weld.
  24. Likes Lis2323, StandarDyne liked this post
  25. #16
    Big Lake/Monticello MN
    Use a pipe flange, then drill and tap, or just drill through, for bolts.
    Easy solution.
    Syncro 350
  26. Likes Lis2323, Roert42, tapwelder, bfjou812 liked this post
  27. #17
    Aug 2022
    Thanks for all the good advise. Yes, the pipe appears to be cast iron Just trying to make a post stand and didn't want to use a flange, but will bolt it up as suggested.
  28. #18
    Apr 2022
    I think most of us were referring to the barbell weight, not the pipe, when we said it was cast iron. Every "black iron" pipe like that (at least that I have seen) has just been mild steel as far as I know...
  29. Likes Lis2323, Roert42, 12V71 liked this post
  30. #19
    I kept these around for post stands..
    80 pound tractor cast iron wheel wheel weights
    Here’s one anchoring a pneumatic paint shaker.
  31. Likes MinnesotaDave liked this post
  32. #20
    Easy solution.
    That’s no fun.
  33. #21
    I have found by per heating I could weld most iron with E6013.
  34. #22
    Oct 2019
    Australia
    Bet it cracked after you walked away
  35. #23
    No it work ever time.
    My anvil stand was done that way I post photo of the anvil and stand over 50 years old and still holding.
    A lot of heat does thd trick.
    Note I did this trick on my tools.
    Costumers paid for correct rod and per heating.
    Quote Originally Posted by Woznme View Post
  36. #24
    Oct 2019
    Australia
    Be nice to see that pic if you still have it
  37. #25
    Here photo I post a few weeks ago
    Dave Name:  20220807_184250.jpg
    HF 170 welder
    HF 4x6 band saw
    South Bend 9N
    Mill
    B&D mag drill
    Victor torch
Page generated in 1,713,277,336.64226 seconds with 20 queries
