Results 1 to 25 of 49
Thread: What do I use to weld this cast iron
    Ct
    This is a wheel for an excavator track, I have to build up the middle ridge so that the excavator track won't keep slipping off. This is some sort of cast what do I use to weld it? I was thinking about wrapping a flat bar around the wheel and welding it on. What do I use, 7018, dual shield, or regular mig wire? Any ideas? Name:  20220926_143931.jpg
    Re: What do I use to weld this cast iron
    Should be steel. And that idler won't hold the track? Looks pretty good from here.
    I think the track is worn enough it can't be tensioned properly.
  3. Likes Lis2323, 52 Ford, scsmith42 liked this post
    Ct
    I hit it with the grinder in it showed yellow Sparks like it was cast iron or something
    Apr 2022
    Should be steel.
    That would be my guess, too. Never had any problems with cast steel.
  6. #5
    Ct
    Well I guess it could be cashed steel to be honest I wouldn't know the difference between cast steel and cast iron
  7. #6
    Nov 2014
    Southern CT
    Is there another one of those on the other side of the machine? What does that one look like? I'm no excavator mechanic but I question why that track comes off, and if making that center ridge thicker is the best fix. Could be wrong, IDK.
    Ernie F.
  8. #7
    Ct
    I don't know wnything about thesef machines, but that's what the customer ordered lol, and he says he'll bring the other one once I'm done with this one
  9. #8
    Drill a small hole somewhere. If it puts out curly chips that are long, it's steel. If it puts out either tiny granules, or really small chips, it's cast iron/semi steel.
    Cast.........use high nickel rod. Steel............use anything you'd normally use.
  10. Likes rhunt, welding1 liked this post
  11. #9
    Mar 2021
    Near Roanoke, VA
    Did the owner look into replacement wheels??
    The aftermarket wheels are relatively cheap,,
    My nephew is as cheap as they come, and he replaced the wheels, as a low cost alternative to welding,,,,,,,,,,
  12. #10
    The customer is always right, But I've done a pile of track work over the years and I'm betting he's got bigger problems.
  13. Likes scsmith42 liked this post
  14. #11
    Jun 2008
    Central California
    If he is correct, a shrink-fit band might be fine, after cleaning everything well and maybe using a few plug welds as insurance. If he isn't right, asking lots of questions to bring out other possible problems, like excessive wear in joints leading to a loose track, or damaged components causing the track to ride up in places...might allow him to fix them and not pay for unneeded work he'll be pissed about later.
  15. #12
    Quote Originally Posted by Oldiron2 View Post
    No to the band, weld build up only, the band will get pounded loose and then you have 8' of steel bar tangled up in the track rail/chain. seen it done before and I was the one that had to cut that junk out.
    Odds are that the pins and bushings in the track rails are shot, when that happens the track will snake side to side and nothing but tension will hold it on the machine but by that time you run out of tensioner travel. A quarter inch of wear per pin X 45 links is how much additional length? Been there.
  16. Likes CAVEMANN liked this post
  17. #13
    Jun 2017
    AJO, ARIZONA
    I can't imagine ANYTHING subjected to what that wheel & yoke goes through being cast iron, it's gonna be a weldment, cast steel or forged steel and may contain some manganese. You will know the difference between cast steel and cast iron, 7018 would be a good choice, I'd give it some preheat.
    UNITWELD 175 AMP 3 IN1 DC
    MIDSTATES 300 AMP AC MACHINE
    JEFF
  18. Likes 12V71 liked this post
  19. #14
    Mar 2009
    MN
    I'm with this guy. Tensioner probably out of travel and track never gets tight.
    My name's not Jim....
  20. Likes CAVEMANN liked this post
  21. #15
    My last track job last December, $60K in parts alone.
Size:  108.3 KBName:  20211214_090609.jpg
Size:  177.8 KBName:  20211214_090628.jpg
  22. Likes 52 Ford liked this post
  23. #16
    Use small drill and drill into wheel. If make a powder then it is cast iron . If get nice chip then steel
  24. Likes 52 Ford liked this post
  25. #17
    Ct
    They are rubber tracks he said
    Does that make a difference?
    So you think the band is a bad idea? Building up with weld is better?
  26. #18
    Sounds great.
  27. #19
    It could work with rubber if it's welded well... Maybe. But now I'm thinking the guides on the rubber band tracks are bad. It's funny because the tread wear on that Idler screams steel track to me.
    Oh, the steel cords in rubber tracks stretch too.
  28. #20
    Ct
    Well I guess i could weld it and see what happens, in my experience people don't like to change their opinion on what the problem is
    I don't have a lot of experience with this type of stuff
  29. #21
    Dec 2020
    Virginia, USA
    If it's cast iron, wouldn't the correct repair be to pad it with nickel or some other cast iron compatable rod, then cap that with wearfacing?
    If it's cast steel, why pad it with 7018 instead of wearface?
  30. #22
    Since we now know it's got rubber tracks, it could indeed be a cast iron Idler. Do the tests and find out.
  31. #23
    With steel tracks hardfacing is a no-no, it eats the track chains.
  32. Likes 52 Ford liked this post
  33. #24
    Jun 2008
    Central California
    Part of his response is likely to depend on how he is approached. If he knows you don't claim to be an expert and you don't start by telling him he's wrong, but you make him know you want him to be sure about what needs to be done, and maybe help him figure it all out, he's more likely to try to think it all through.
  34. #25
    Outside of Raleigh, NC
    My thoughts as well. That idler wheel does not appear to need building up.
    Miller Trailblazer Pro 350D
    Miller Suitcase MIG
    Miller Spectrum 2050
    Lincoln 210MP
Page generated in 1,713,311,886.89008 seconds with 20 queries
