Need to make 1' - 6' diameter steel tree rings. Help
5K views 64 replies 11 participants last post by  Broccoli1
I haven't been on this forum since I was in welding school 6 years ago. Somehow I ended up with a landscaping business, but have also incorporated building things out of steel for folks and am looking to add more things to sell.
Right now, one of my customers is looking for steel tree rings ( circular shaped steel edging) , and I am having a hard time figuring out how to make them. I would also like to be able to create archways out of tubing, so that is also something to consider.
My main trouble is finding a machine that I can roll 3" flat bar (up to 1/8") on. Anything less than a tree inch width is really just too short for tree rings. I have an oxy acet setup, but would like to have a roller I can just. Rank stuff out on.
#3 · (Edited)
Well, you either need a big ring roller ($$) or a slip roller ($).
If I were you, I'd try making a product to match this stuff. https://www.lowes.com/pd/COL-MET-Brown-Powder-Coat-Steel-Landscape-Edging-Section/3015399 or a similar metal edging system. That way, you have the opportunity to upsell the client on edging their flowerbeds, too.
The only annoying thing about the product I linked to is that the stakes come spot welded to the edging and you have to pop them loose before installation. That said, I've installed it on customer jobs and at my own house.
#7 ·
Unless you're going to make 100's of these rings just get your steel supplier or a fab shop to roll them for you. Even if they had an hour minimum could probably roll you a years worth. There are smaller 3 roll rollers and I think it was Shootr on here that made his own. Still by the time you did all that you could just get them rolled. It's not much different than shops that occasionally have to make a tank. It's not worth buying plate rolls you're only going to use intermittently.
#8 ·
You are talking about two different tools.
A slip roll will make the flat bar into rings as shown above.
A pipe or tube roller will make the arch you mentioned.
How many of each will you need and how frequently?
How large of an arch do you need?
Do you have the space for the tools and the material as it goes in and out of the tool?
As Welder Dave said, it may be easier or cheaper to have a shop make them for you. Just add 10% or so to the price and charge that to the customer.
I have both tools and use them on occasion. They have paid for themselves several times.
#9 ·
Yeah I might have to just pay a shop to do a couple. I would really like to be set up in my fab shop, but I just moved and currently have no shop. For those that have a slip roller, have you tried doing 1/8" flat bar in it? I eventually found one manual roller(that does 3" wide up to 1/4"!) But it's 2k and that's not going to happen.
#10 ·
I have an old Pexto 36-inch slip roller made for 1/16" material.
I regularly roll pieces of steel that are 1/8" thick 3 to 4 inches wide and occasionally up to 12 inches wide.
I have even rolled stainless steel flat bar 1/4Ă—2" on that roller.
Keep the material near the ends and not the center. Get a motor or electric drive like the Harbor Freight pipe threader. I use the pipe threader on the slip roller and pipe roller. I even make an adapter for the HF pipe threader to square drive for rollers.
#13 · (Edited)
IMO your client is not considering the right product for his application unless I am missing something
By tree ring do you mean a 3foot diameter ring at the base of a tree ( sitting on the ground) to act as a border?
If so , 14 gauge coreten would be easy to roll 4-8 “ tall strips” and not worry about corrosion
#16 ·
That's very smart about the partial radius. I also have an oxy torch setup, and was wondering if that might be a good way to go?... Especially for the smaller circles. Would bumping it beat the hell out of it?
I was wondering maybe I should make a wooden Buck and wrap it around and weld it?
I called four fab shops this afternoon and nobody said they would roll 3" x 1/8" flatbar... They said 18 guage at most.
#18 ·
Honestly, I think the premade ones look like ****. If I get/make a roller down the road, I can make them cheaper and it is something I can sell( currently landscaping to make money, but am trying to get into landscape design/metal landscape things.
Not reinventing the wheel, just making it prettier and profitable. A welded steel ring at 1/8" just looks very clean and intentional. This will be my first thing I can sell to someone that is landscape related and I really need something to put on my Instagram/FB to let people know that I am capable of building things(as simple as this is)...one thing always leads to another.
It's really a B that 3" wide rollers are so expensive. Right now I'm inside taking a break from playing with some 1" strap out in my yard and thinking about wooden bucks and torching it.
#25 ·
The issue I see with something that light is that it'll get bent up when someone inevitably hits it with the mower deck.
The edging around the front of my house is all pressure treated 1X6s trenched in then staked in and I just run the mower deck right up against it. No weedwacker needed afterward.
#32 ·
Harbor Freight pipe roller for $249 and flat dies for 3 inch wide flat bar from swag off road for $209.
Could be done on site for custom sizes or pre rolled for standard sizes
You can fit up to 4 inch wide flat bar and roll using 3 inch dies
I made my own flat bar dies out of delrin I had on hand since I am cheap.
I checked the swag website, and could not find anything for 3" flatbar dies.
#28 · (Edited)
#29 ·
The Swag Hulk roller is a pain for complete circles. It’s a bit of a chore removing and replacing the drive roller every time.
Not impossible just annoyingly time consuming. (says the retired guy with more time than brains) lol
#33 · (Edited)
I think "buck" is a more appropriate term... maybe? https://en.m.wikipedia.org/wiki/Last
Edit: I was going to link to the definition of "buck", but apparently that's an uncommon term, too??? [emoji849]
A buck is a forming tool.
In metal spinning (look up metal spinning, it's kinda cool), the buck is the form that they shape sheetmetal around.
I think some people call body dollies bucks, too.
#37 ·
Absolutely.
I wasn't sure if he couldn't find that specific die or all the other dies.
A little thinking ahead of what else he might want to make would allow him to use the same die in multiple ways.
I just would not use a die for pipe or tube to roll flat.
