I finally got around checking out my USA made Firepower 250 torch set up. The knobs on the handle were very hard to turn. But as I keep working them they are getting better. I did order a rebuild kit and proper lube to go through it. I didn't realize they had a special cleaner. Can I just use something on a q-tip like brake cleaner, or iso alcohol? Or do you really need the special stuff? My order all ready shipped so I would have to find something local.
I turned the gas on and checked for leaks with soapy water. The hoses are junk. On the ox regulator there is a small leak on the threads that go from the supply pipe into the regulator body. I assume this is just a pipe thread? Can I just tighten it or should I use some kind of thread sealer on it. Maybe teflon tape?
I found no other leaks. When the new hoses get here I will retest everything.
Please advise. Thanks.
