After using it for about a week now I absolutely love it. Total game changer.
Picked up a 6” vise on eBay for it. No need for an expensive milling style vise that has a small opening. The vise is where it is because I sometimes put long pieces on the front of the table and I don’t want it in my way all the time while still being in a useable part of the table.
Learning to set it up was extremely easy. It’s very straightforward to what is on the screen. There is a few settings you can change but there’s really no need.
If you use it in “intelligent” mode it will automatically gauge the proper torque setting as well as ideal feed speeds. In standard mode it’s a preset value determined by the selected fastener size, which you can manually
Change and you set the speed yourself.
The thread pitch is automatically done in metric when you select a fastener. What it correlates to in imperial I can’t say.
Depth setting being in metric is a little annoying as well but as long as you know 25.4 is an inch it’s very easy to set it where you need. It’s a little trial and error anyhow as the first couple threads of even a bottoming tap aren’t full threads.
In manual or automatic mode it will stop when it reaches the calculated depth however in manual you need to hood forward and reverse. I did not think I’d use the automatic but It’s really great. It hits the depth and brings itself out no problem.
The collars are very easy to use and hold onto the taps great. You just press down on the rim around the tap and it slides into the jaw and a square back that locks the shank from rotating. To remove it you just press down on the collar again no tools required.
I am trying to locate a 5/8” size collet as the largest they give you is 1/2 but the machine will tap 5/8 or 16mm.
Overall couldn’t be happier with the purchase. Should pay for itself in no time.
