What case would one be appropriate to use over the other? I dont plan on any furniture or art stuff just repair. Which rod is most useful? Cast iron, building up bushing and wear areas.
If you have 316 then you don't need 308, 316 will cover for 304 and 316 SSTIm thinking some 308 will be next.
Just to confuse the issue, the Harris people are discussion Brazing and I think the OP is more interested in Braze welding.Go to Harris Products Group and look in the Consumables column and you'll find many answers to "brazing" questions
I have always gas brazed. I'm not sure if it possible to TIG braze unless it is small scale. Most people that use TIG, braze weld.What is the opinion of traditional gas brazing and tig brazing? This is what my common sense would tell me. Anytime you can tig braze you should.
It is not "tons of heat", it is sufficient heat. Brazing is done by heating the joint and surrounding area to the brazing temperature and then adding filler to the joint where it is melted by the hot base metal and is drawn into and around the joint by capillary action.It seems to me with traditional gas brazing you are dumping TONS of heat into the material all in different amounts the further you get away from the repair site. What says Weldingweb.com?
