What other items should I consider getting?
Can I just use Flux cored wire or should I purchase a bottle and gas?
What gas?
Other usefule hints items would be greatly appreciated.
Extra contact tips for whatever diameter(s) of wire you plan to be running. It can be worth the extra couple bucks to get the nice ones but it really depends on your budget and how much wire you plan on running through it. A cart for it is another good thing to have unless you plan on doing a lot of mobile work with it. That's a nice machine, a cart will keep it nice for longer. Eventually you'll get annoyed lugging it around if you're using it indoors anyways. Buy one or build one.
You can use self shielded flux core wire but it makes a mess, is harder to use (at least use well) and it's not a very good idea to do much of it indoors without a respirator/fume extractor. The fumes will pretty quickly stink up most garages/sheds, potentially more than stick could because with a wire feeder you can just keep the trigger down. Solid wire with gas will run nicer/cleaner, be easier to use and won't have nearly as many fumes. Definitely get a cart if you go the gas route.
If you get some gas, go in and ask for C25 or a 75% Argon/25% Carbon Dioxide mix (they're the same thing). That has the best "all around" properties for a machine like yours. There are times to use 100% CO2 and times to use 100% Argon but neither of them really apply to you. 100% CO2 is good for being cheap and if you need a lot of penetration but it gives a ton of spatter and Argon is good for if you want to run the spray transfer mode which needs a lot of amps and is really only good for welding fast in the flat position. Your machine might not have the beans to reliably run spray transfer either.
Otherwise practice practice practice!
