Results 1 to 5 of 5
Thread: Stainless Steel Mig
    Jan 2007
    Stainless Steel Mig
    Seems like I can never achieve a good weld with Stainless steel unless I'am using a Flux core wire. The latest project I used a solid core 316 wire on 316 material with a 75/25 mix.It looks real nasty. Is it me or is the flux core with 75/25 the way to go on all my Stainless projects.I did a 12 piece rotor project made up of 304SS and used 308/309( I forget off off ) with 75/25 and it turned off awesome. I do mostly thicker materials from 1/2 to 2 inches.JB
    Jul 2005
    Escondido CA.
    Re: Stainless Steel Mig
    Try a tri mix of heluim,co2 and argon. Any good welding supply store should have this in stock. Kevin
    Sep 2005
    middle tennessee
    Try straight Argon for SS, works out alot nicer
    Dewayne
    Dixieland Welding
    MM350P
    Lincoln 100
    Some torches
    Other misc. tools
    Dec 2006
    Southern New Hampshire
    I run a lot of 316 dual shield with a 75/25 mix..... it runs awesome. Sometimes I have a problem with worm holing but that is about it.... I found that it is very important to only enough tension on the rollers to feed the wire. I adjust my drive rollers so that when I pinch the wire with my fingers the rollers will slip.... this also ended the problem of constantly breaking the wire. Just my 2 cents
    _________________
    Chris
    Santa Fe, NM
    Generally, over 5% CO2 is not recommended for SS. Ok, I suppose it works, but in addition to oxidizing the weld there will be excessive carbon pickup, causing the formation of chromium carbides, thereby destroying the corrosion resistance of the SS. If your application does not involve a corrosive enviroment, then maybe you don't care.
    Once again, here are the AWS recommendations for MIG gas:
    http://files.aws.org/wj/2006/02/wj20...j200602-46.pdf
Page generated in 1,713,284,325.74687 seconds with 18 queries
