Page 4 of 5 FirstFirst ... 2345 LastLast
Results 76 to 100 of 121
Thread: Saved Another One From The Scrapman!
  1. #76
    May 2004
    Richmond/Midlothian,VA
    Re: Saved Another One From The Scrapman!
    Some nice work Duane. When you talk about soft pad are you using a 3M product or something like it?
    Bruce
    The Welding Chef
    Lincoln Weld-Pack 3200
    NORWELD Stick
    Stanford Hill Farm
  2. #77
    May 2008
    Orange, TX
    Thanks and sorry 'bout that - actually the correct term would be flap disc like this:
    vs. a sanding disc like this used with a flexible backer (that I refer to as a "soft pad").
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
  3. #78
    southeast texas
    Any updates on the build, Duane?
    1960 Redface SA-200 F 162
    1973 Black face SA-200 F 163 with 5" chop
    2013 Miller Trailblazer 275
    2013 GMC 3500 welding car
  4. #79
    Feb 2005
    Louisiana
    Yes, inquiring minds want to know!
    A few of my toys !
    LinuxMint
    Manjaro
    Miller Roughneck 2E
    Lincoln WeldPak 100
    HTP MTS 160
    Chicago Electric 80amp Inverter
    Victor O/A
  5. #80
    May 2008
    Orange, TX
    Well . . .
    . . . all subassemblies (starter, alternator, governor, mag, water pump, idler board) are rebuilt and ready to go, main generator ready, battery box rebuilt and all the parts including a new radiator, all hoses, rheostat, armature bearing, Murphy gauges, etc., etc. needed to put it back together with just the engine rebuild left to do. And of course media blasting, sanding, prep and painting.
    I keep telling Judy the next one I put back together from pieces is going to be mine. Getting closer I guess.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
  6. #81
    southeast texas
    Sounds good my wife can't wait for me to finish mine
  7. #82
    Mar 2012
    New Philadelphia Ohio
    Hey Duane, any progress?
    1973 Lincoln SA 200, Already replaced shunt coils, Idle board (SOLD)
    1984 Miller Dialarc 250HF, Miller water cooler, 250 AMP water cooled torch, you know the worx.
  8. #83
    May 2008
    Orange, TX
    Nothing new at this point as project funds still won't allow addressing the remaining engine overhaul right now.
    Thanks for askin'.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
  9. #84
    Jul 2013
    Duane Where you getting the long shrink tube for leads coming out of generator?
  10. #85
    May 2004
    Amazon, or maybe a fishing/tackle store?
    Bruce
    The Welding Chef
    NORWELD Stick
    Stanford Hill Farm
  11. #86
    Jul 2013
    I picked up some from the electrical supply
  12. #87
    May 2008
    Orange, TX
    McMaster Carr.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
  13. #88
    Nov 2010
    Texas
    Duane, I pulled my 1969 SA out of the corner today. Thinking about starting to work on it again, most other projects out of the way now. I need some more inspiration, have you made any more progress on this machine?
  14. #89
    May 2008
    Orange, TX
    Unfortunately not.
    Like a lot of other folks, money has been tight and my "toys fund" has been suffering right along with the day-to-day. Still stalled at the engine overhaul and then paint and reassemble.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
  15. #90
    Oct 2013
    cntrl FL
    Hi duaneb , I was doing a search and happened to stumble up on this post. How's that machine turning out?
    SA 200s : 1944 1945 1963 1965 1969
    1981 SA 250 D3.152 DC only
    2004 Ranger 10,000
    Lincoln Pro Mig 135
    Miller Load Bank
    Hobart GPB 258 Pipeliner
    Hobart GPB 261 Mainliner
    Hobart Airforce 250
    Everlast PA 200st
  16. #91
    May 2008
    Orange, TX
    Unfortunately still in pieces. Life has been getting in the way I guess.
    Just sent another machine that belongs to a pipeliner from Louisiana home Friday that was here for some maintenance issues and to have a Weldtron remote installed. I also have a short hood and red face here I'm working on now.
    I keep telling myself I'll get it back together soon and I'm glad I don't have to make my living with it.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
  17. #92
    Oct 2013
    cntrl FL
    Yeah i know what you mean. Sometimes i get burn out working on the same things, and give it a break for awhile.
    2004 Ranger 10,000
    Lincoln Pro Mig 135
    Miller Load Bank
    Hobart Airforce 250
    Everlast PA 200st
  18. #93
    May 2008
    Orange, TX
    In the case of this and my other "pet projects" it's a matter of more important things have taken priority.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
  19. #94
    Sep 2008
    SF bay area, CA
    if you were closer i would bring my 1300 hour red face with a locked up rusted #2 cylinder over and have you set it right. i just dont have the time to screw with it like it should be screwed with.
  20. #95
    May 2008
    Orange, TX
    Hey, the short hood and red face came from about as far away so . . .
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
  21. #96
    Sep 2008
    SF bay area, CA
    Whats the $$$ to go through one?
  22. #97
    May 2008
    Orange, TX
    Quote Originally Posted by Dualie View Post
    PM sent Dualie.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
  23. #98
    Jul 2010
    Yukon, Oklahoma
    Duane,...64 Redface refurb cost?
    Lincoln 305G
    Union Carbide Torch
    Don't Worry About the Mule~
    Load the Wagon!
  24. #99
    May 2008
    Orange, TX
    Quote Originally Posted by Joe Bill Moad View Post
    How long is a rope?
    That can vary widely depending on what the unit needs and what the owner wants.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
  25. #100
    Jul 2010
    Yukon, Oklahoma
    Thanks Duane.....it needs wiring, Belt, etc.........runs good and welds good as is.......just got back from Oreilly's and picked up 80.00 worth of wire, connections, New belt....etc.....I live 5 miles from Bills in OKC......think I will just go the easy route since it is working properly......later would like it appreciated.....$$$$$$$
    Lincoln 305G
    Union Carbide Torch
    Load the Wagon!
Page generated in 1,627,615,348.15144 seconds with 12 queries
