Page 2 of 2 FirstFirst 12
Results 26 to 36 of 36
Thread: Icing On Red Velvet Cake
    Re: Icing On Red Velvet Cake
    Beauty job Duane, is the owner going to have it covered/inside when not in use?
    Thermal Arc Fabricator 210
    1970 Lincoln Redface
    Miller 150 STL
    Still need a Syncrowave and a plasma and a milling machine and a lathe and a bigger shop and a....
    southeast texas
    Pm me and I can give you some more detailed info on changing that seal
    1960 Redface SA-200 F 162
    1973 Black face SA-200 F 163 with 5" chop
    2013 Miller Trailblazer 275
    2013 GMC 3500 welding car
    May 2008
    Orange, TX
    Want to share with the group?
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    May 2008
    Orange, TX
    Quote Originally Posted by Canoe2fish View Post
    . . . is the owner going to have it covered/inside when not in use?
    I was told it's his back-up unit but he chopped it to be able to see out the back window so I don't know that it won't wind up on his rig. ??
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
  5. #30
    May 2008
    Orange, TX
    Quote Originally Posted by 60redfacer View Post
    For everyone's benefit, 60redfacer pointed out that by cutting off the hand crank support from the bottom of the radiator mount, one can service the front crank seal without pulling the radiator and jacking the engine up. It's that hand crank support that's in the way.
    Good tip and as he pointed out - no one uses those things anyhow.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
  6. #31
    southeast texas
    I added my tip to the sticky, for those who would be interested in reading. In there I added the part numbers for seal and speedy sleeve, also a cheap place to order some engine parts
  7. #32
    Feb 2012
    Is that hood polished stainless or is it chromed? If u dnt
    Mind me asking how much did it run u and did u just have a fab shop bend it up for u? Looks awsome!!
  8. #33
    May 2008
    Orange, TX
    #8 polished SS and a local fab shop I deal with did the work except for the lifting eye and exhaust openings and hold-down bolt holes which I took care of.
    I'll shoot you (and anyone else that cares to know) a PM on the $$.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
  9. #34
    Jul 2010
    Chicago
    Duane;
    I must say that is a sweet job!
    Picked this up from the fab shop this afternoon and got it fitted up and installed. This is the 5" chopped unit I put back together and detailed out for the owner.
    Looks pretty sexy me thinks.
    Attachment 124871
    Attachment 124881
    Attachment 124891
    Attachment 124901
    Brake dies still left verfy fine marks thru both layers of the protective film on the #8 polished 16ga SS for the 180 degree side seam but not that noticeable after a wipe down. Photo makes them look worse than they are.
    Attachment 124911
  10. #35
    Nov 2011
    North Idaho
    Duane,
    Love your attention to detail, and quality work. Nice job!!!!!
  11. #36
    Jan 2008
    Lansing, MI
    I think I was MIA when you posted this originally Duane. It was just a bit after my now ex wife and I had separated. I wasn't on for several months during that time.
    Great job as always and VS. 2.0 will undoubtedly be even better!
Page generated in 1,627,619,864.68242 seconds with 11 queries
