so i get a HF 80 amp welder and for me on average 120 volt 15 amp circuit no way am i getting 80 amps seems like 55 amps. with Tig torch i can start arc and see the 80 amps cut back in a second with smaller and darker arc. maybe it senses 120 volt line voltage drop and is cutting back on weld amps automatically. obviously machine rated at 20 amps at 120 volts should be tripping 15 amp circuit breaker.
so i try 1/16 dia 6013 and 7014 rod that burns ok and at 80 amps setting (putting out only 55 i believe) and even 55 amp setting the rod will be red hot if burned all in one use. so machine auto limits weld amps maybe cause 120 volts goes below a certain minimum voltage level at high weld amps ??
so 1/16 dia 6013 rod i weld some 1/8" thick 1-1/4 square tubing. actually welds pretty good. normally i prefer 6011 or 7018 rod so i check out Amazon and see they sell Hobart rod 1/16 in both 6011 and 7018 and i ordered a pound each size
anybody use 1/16 diameter 6011 and 7018 ?? ........with 6013 seems to run the same as bigger diameters as long as welding 1/8 thick or less metal. when using 1/16 dia rod on 1/2 plate seem like weld is maybe not hot enough. if i weave side to side a lot at max amps rod can take it makes a ok bead. maybe it is just 1/16 6013 rod is not the best rod to use on 1/2 plate
