Hi everyone, I am fixing up an old machine that I picked up and have run into a snag. First off it is an AEAD-200LE from around 1978, serial number is HH063882. It was working pretty well but was incredibly dirty inside so before mounting it to its new home I decided that I would wash out the inside as it had a huge mouse nest in it, a lot of poo, and a thick layer of dirt. I just used the garden hose, no solvent, and I blew everything out immediately with compressed air and let it sit in the sun for a few hours prior to starting it.
It fired right up, AC and DC welding circuits work fine, 115v DC outlet works fine, but neither of the 110v AC outlets work. After messing with it for a while I noticed that one of the big 12 ohm resistors directly under the outlets was smoking. I shut it down, found that one of the clamps was rusted really bad, so I cleaned that up and still have no power. My meter says that it's only making about 4-6v AC.
Measuring between the end terminals on the resistors, the "good" one reads 11.2 ohms, and the "bad" one reads around 13 ohms. Between the clamp on the bad one and the bottom terminal, I get about 3 ohms. So I guess I feel like that resistor may not be great but it's not dead?
The manual says there is a fuse next to the 120/240v terminal strip. I don't have a fuse, I have what I think is a 10 amp auto resetting breaker, but I think it's not tripped - I have continuity across the two terminals, but one of them goes into some sort of little round thing (thermistor maybe? Am I even checking continuity correctly on that?
I read some other threads where the fine adjust rheostat caused problems, before I go spend money on replacing that, what else should I be checking? Anything I missed?
