I cut aluminum with normal worm drive skil-saw. I've also been known to use the table saw, router, on chop saw on aluminum. Nothing special. It's loud and the hot chips go everywhere.
Steel on the other hand, I use a Milwaukee dry cut saw. Lower RPM, works great. Metal cutting saw does 3700 rpm no load, wood cutting saw does 5800 rpm. In addition, the open vents are a recipe for a short circuit when cutting metal with a normal saw.
I'll sum it up with a story. A couple months ago, my Dad, the carpenter, called me because he was having a hard time drilling a 5/8" hole in some steel plate. He had burned it up the bit and was calling from the hardware store to see if he should buy some whiz-bang drill (read as $$) the dude recommended. I asked him what speed he had the drill press set at. As high as it would go, was his reply. What? Are you nuts, I scoffed. Slow that sucker down, as slow as it will go. Did you think to sharpen the drill? Nah, I figured it was faster to buy a new one, he mumbled. What? You live 35 miles from town? Go home, sharpen your drill, slow things down and drill the hole. The next day he thanked me. He said it drilled like butter. Nice to impress the old man once and a while. Remember, with metal, the harder it is the slower you go.
