Butane lighters
25K views 39 replies 27 participants last post by  smawgmaw
DISPOSABLE LIGHTERS WARNING
The following story appeared some time ago in an American company’s staff magazine.
“It has come to the attention of the Safety Program that recently a major railroad has experienced two (2) fatal accidents caused by disposable Butane cigarette lighters. These accidents occurred inwelding areas while employees were welding with the butane lighters on their person.
A spark from the welder landed on the Butane lighter, burned through the case, exposing the liquid
Butane, which then exploded. One lighter was in a shirt pocket and killed the individual instantly.
The other employee had a lighter in his pant’s pocket. The explosion blew the man’s leg off - he died a short time later.
There is the same amount of force in a Butane lighter when it explodes as there is in
approximately three (3) sticks of dynamite.
HARD TO BELIEVE, BUT TRUE
You should be aware of the danger present with these lighters in areas where welding and flame cutting operations are performed, also anywhere there are sparks or an open flame.
#6 ·
I used to be quite a pyro when I was a kid. Butane lighters would either erupt into a good size fireball( about the size of a basketball) or it may explode with about the force of a good firecracker. I could see some serious burns and maybe shards of plastic spearing into the skin, but I highly doubt it would blow someone's leg clean off.
#3 ·
Not even close! Whoever wrote that just doesn't understand physics, math or chemistry.
Butane doesn't even explode in the same sense that nitroglycerin or other true explosives do; a mix of it plus air undergo a very rapid burning under normal circumstances. Also, the amount of energy contained in the small lighter is considerably less than that contained in a single stick of even low-powered dynamite.
Just 'cause you see it on the internet, (or even in a newspaper or magazine) does not mean it's correct or true.
#9 ·
I had a Bic brand lighter explode but I was not welding. I was living in a small cabin at the time which had a propane space heater in the bathroom. Said heater was near the bathtub and I had laid my cigarettes, lighter and ashtray on top of the heater, as I had done all summer long, while I was taking a bath. It was no longer summer and I had just lit the heater and ran a tub full of hot water. I was not looking at the time of the explosion, in fact I had laid back in the tub to get my hair wet. Sounded like a shotgun went off in the bathroom, and I did see the flash through closed eyelids. The lighter case had split but was still right near the heater. There were no scorch marks on the wall or heater and no plastic shards. It was noisy and bright, and I never laid another lighter on that heater but there were no injuries or even minor damage as a result of the explosion. Still, I always carried a Zippo after that, if nothing else that butane was very noisy when the lighter split open. Quit smoking a little over 2 years ago so I no longer carry a lighter at all.
#14 ·
I have heard about one set of circumstances where a disposable lighter can do massive damage. Long before I became a weldor, I did some industrial cleaning. This one aluminum foundry, when you go through security you have to hand over any butane lighter you may have. Zippos are okay, or they'll even give you matches. The rumor is that some disgruntled employees used to toss butane lighters into the remelt furnaces which are full of liquid aluminum, resulting in a large explosion and a ruined batch of product.
#19 ·
"The blender looks fine to me, all I saw was a quick fireball, no flying parts."
I did not think of the difference between burning an intact lighter casing vs the blender method. but my point was that the blender is almost unharmed... stick of TNT indeed!
Now, as I see it, what happened in the blender video is:
lighter in blender is smashed to bits, releasing butane.
butane evaporates, seeps out of jar and may have been ignited by the (presumably Brushed) motor, resulting in a quick flash fireball. and if you look, not all fuel in the jar appears to have burnt and keeps burning at the end of the vid.
I suspect the fuel took a bit to leave the jar and light, and it probably vaporized more slowly in the jar.
igniting an intact lighter would be more of a bang, but nowhere near bad enough to dismember anyone...
#21 ·
According to the rumor it should have been the same as a dozen sticks of dynamite, or is it in the kiloton range by now ?
Do you realize that the 'flints' are really made of "Mischmetal(*)" and composed of rare earths, some of which have radioactive isotopes; if he had just spun that blender fast enough and had enough 'flint' present .....
* __ Mischmetal (from German: Mischmetall - "mixed metal") is an alloy of rare earth elements in various naturally-occurring proportions. It is also called cerium mischmetal, rare earth mischmetal or misch metal. A typical composition includes approximately 50% cerium and 25% lanthanum, with small amounts of neodymium and praseodymium. Its most common use is in the "flint" ignition device of many lighters and torches, although an alloy of only rare-earth elements would be too soft to give good sparks. For this purpose, it is blended with iron oxide and magnesium oxide to form a harder material known as ferrocerium.
Carl Auer von Welsbach was not only the discoverer of neodymium and praseodymium, and co-discoverer of lutetium, but was also the inventor of the light-mantle (using thorium), and of the rare earth industry. He built a factory to manufacture his mantles, and had discovered that the necessary thorium was available from monazite sand, which at the time originated from Brazil, but which soon thereafter was also coming from North Carolina and India. But after the 6-10% thorium content had been extracted from the monazite, he had a lot of lanthanides left over, for which there was no commercial use. [The 1% of cerium that was added to the thorium oxide to improve the performance was all that could be found initially to usefully employ any of the remaining lanthanide.] Thus, he began exploration for applications to which the rare earths might be put. Among his first discoveries/inventions to bear practical fruit turned out to be Mischmetal and the lighter flint, both of which continue in use a century later. It has been pointed out that von Welsbach was one of the few scientists that has ever been honored with a statue in a public square. The company he founded is still in the rare earth business, and indeed, still in the lighter flint business.
Preparation:
Historically, mischmetal was prepared from monazite, an anhydrous phosphate of the light lanthanides and thorium. The ore was "cracked" by reaction at high temperature either with concentrated sulfuric acid, or with sodium hydroxide. Thorium was removed by taking advantage of its weaker basicity relative to the trivalent lanthanides, the radioactive radium isotope daughter products of thorium were precipitated out using entrainment in barium sulfate, and the remaining lanthanides were converted to the chloride. The resulting "Rare Earth Chloride" (Hexahydrate), sometimes known as "Lanthanide Chloride", was the major commodity chemical of the rare earth industry. By careful heating, preferably with ammonium chloride or in an atmosphere of hydrogen chloride, the hexahydrate could be dehydrated to provide the anhydrous chloride. Electrolysis of the molten anhydrous chloride (admixed with......[continued]
(From: http://en.wikipedia.org/wiki/Mischmetal)
#23 ·
I never had a lighter blow up in my pocket, but I had 3 Blue Ribbons blow up in the trunk of my 54 Ford when I was in high school. The car had been out in the hot SC sun all day while my friend and I were swimming in his pond.
When they blew up we didn't know what it was and if made the back of the car go up and down. Not knowing what it was I opened the trunk real slow thinking maybe I had left a gun back there.
After seeing the mess it made I know one thing. You wouldn't want to have a beer blow up in your pocket - it would be a terrible waste of good beer and it might make you mess up your pants. :D
#24 ·
The myth that has circled the globe. Now there are job sites that prohibit those lighters on the job site and yet the original memo was fictitious.
I DID witness a guy throw a butane lighter against a cement wall and have it blow but no fire, just a pressure release. It was one of those "hold my beer and watch this" moments. He had to throw so hard his arm hurt and it took him three tries.
#39 ·
I always found I had to relax to be able to make. Maybe it's just me. I doubt I'll ever go in my pants due to any type of accident (barring death or other release of control over all four sphincter muscles holding it in).
At the burn temperature and rate of pressurized (liquid) butane, WORSE case scenario, you could expect second degree burns over 9-18% of the body (remember the rule of nines). It'll hurt. You'll need silvadine. Possibly even a skin graft. Death? Possible depending on sanitation. Infection is the number one killer of burn victims. Just thought I would chime in.
#30 ·
Has anyone ever tried the "flint trick"? Next time you have a butane lighter that goes empty, remove the flint and spring from the lighter. Stretch the spring a bit, and wrap it around the flint a few times. Get it good and tight as the spring will expand in the next step. Hold the end of the spring, the end without the flint, and hold the flint in a flame from another lighter. When the flint glows red hot, throw it against a hard surface, and you will get a nice shower of sparks. While I have done this indoors, make sure no really fluffy pets are around.
