11K views 38 replies 16 participants last post by  ronsii
Hi everyone. I am an amateur welder building a new home. The home is passive solar design and as such, has a cement slab (concrete stained) floor and main floor walls are cement (8 inches thick) with rebar and poured cement block wall.
I would like to build some "floating stairs" to the second floor, and the idea I like the most is to attach a metal plate, lets say 5 inches wide by 1/4 inch thick(?) to the wall going upward with concrete screws or most likely concrete expanding anchors into the cement. I would like to then attach a 3 or 4 inch steel tube perpendicular to the plate (ie. one end welded only) and have this tubing extend out about 36 inches from the wall to support a 40 inch wooden stair tread attached to the tubing.
I have 2 questions: 1) Will the well support a load of say, 200 lbs safely with a lever arm of 40 inches max from the weld point, and if so, which size tube would be the best without overkill. and 2) Is there liable to be flex in the tube as weight is put onto the step, because if so, I would attach an angle iron below each step at 45 degree angle down to another plate as a brace.
I would prefer to not have to 45 degree brace the bottoms for aesthetic reasons if I could just float the stairs. Any thoughts would be appreciated.
I know there may be questions about equipment, etc. I have access to a small mig with a flux core wire, but I don't think it will be hot enough, and will likely do the welding with a larger mig (farm model) with sheilding gas. That is the extent of my welding terminology, sorry, although I will have my father in law, who is a welder /farmer by trade to consult as needed.
Thanks.
#3 ·
Is the finished wall going to be built out to accommodate insulation plumbing, or electric. As it is I don't think the 5 x 1/4 is going to give enough support, also you may want to use a tee shape tapered to support the steps. That could be made out of 5x1/4. The bottom leg of the t would be tapered and the top would be routed into the step. This should give a cleaner look with less mass.
#6 ·
No, the finished wall will be just the surface bonded cement, sort of a stucco finish. Wiring will be on the wall in conduit. I could go larger thickness of plate. I like the idea of the T with routering into the wood. Would likely look quite nice. I suppose the T would have to be 2 inch or more?
#8 ·
Will your building structure that you are mounting to support the static load of the floating stairs? Do you have any idea of how heavy your stairs will be? Why type of live load are you designing for? Do you anticipate carrying anything heavy up these stairs? All questions you should have answers for before breaking out the farmer mig and beginner welder combination. Do you have local building permits/inspection requirements to satisfy? One other thing how does your liability insurer feel about your home built floating stairs?
#11 ·
As far as wall support, it's hard to say without a lot more info on the wall. Length, height and so on also play a part in what it would carry. If I was designing a house and wanted to "float " the stairs, 8" of block wouldn't really be my 1st choice, even with bar and grouted solid. I've seen plenty of walls that were supposedly grouted" solid" that weren't because the masons were crap.
Personally I'd have wanted the wall thicker than 8", even if poured solid concrete. I know 8" of solid concrete would hold the anchors solid. but if the wall is long and unsupported, going up say 16'+ ( assuming 2 story) might cause issues with the wall cracking in the long run. Not so much from a structural issue but cosmetic if you are leaving the wall as is.
Block is very poor structurally in a side load configuration. That's why they would have grouted and used bar inside. However I don't know how they did that, what bar spacing, what quality of grout etc was used. Also 8" block doesn't leave a huge cavity to grout solid. Most "solid" walls I've seen grouted were all out of 12" block so you had a good size cavity to fill all the way down. Even then I've often seen where the masons were sloppy and filled a cell partially and you can't get grout or bar down those cells, so below that you have a hollow wall.
A lot of this would change if there's something on the back side of this wall to add stability, say a horizontal wall or floor.
As far as your steel, if I am visualizing this correctly, 4" tall heavy wall rect tube should support a step over that distance. 1/4" should be plenty to keep the tread from tipping on the tube. I'd rout the bottom of the wood to accept the plate at a minimum. If you are going with really heavy wood treads, you can probably hide a lot of the tube as well. I've seen some skeleton designs where instead of tube they build from pieces of plate that get cut into to heavy treads. That would require more design though though.
A bit of background on me. I studied Architecture in college and spent 15 years doing concrete for a living, both poured walls and decorative stuff ( stamped and stained concrete). I'd love to see what your stained floor ends up looking like.
#14 ·
The Wall is 8.5 feet high, dry-stacked 8 inch block wall with every third core rebar'ed. The cores were filled with a pumper truck and plasticizer to make it flow better, so I think there was pretty good filling of the cores. The outside is "surface-bonded" with quickcrete s.bonding cement which includes fiberglass. Strength of the wall is twice that of masoned block wall and even better than that side flexion/torsion due to the 1/8th inch minimum thickness bonding. The wall is also set into 7x11 inch supporting I beam on second floor, so I'm not too worried about side forces on the wall.
I could, however put rods with backing plates all the way through the wall to ensure hold. I will make sure to rout the bottom of the tread (have some thick 3" lumber) to get a good fit. I'll include one shot of the wall that also shows the floor a bit for interest sake.
#13 ·
I am far from an expert but here are a few thoughts. You say a load of 200 lbs but that doesn't allow for two movers carrying a 100 lb piece of furniture up. It also doesn't allow for two firemen carrying someone down on a stretcher (I saw this happen once with a heart attack victim, they could not get him down the spiral stair case and had to lower him down the side of the building from the window). Another though is your local building department, don't you have to submit drawings for your permit? If you do it is likely they will want an engineer's stamp on that stairway. If that ever came down all at once I would hate to be under it.
One of my clients has a stairway supported by a thick glass wall on one end, looks pretty cool. There is a hardwood structure in the middle of two back to back flights (acts as a hand-hold) with the glass on the outside ends. There are 2" chrome plated pieces of tubing with caps on them supporting the treads thru 2" holes in the glass. Believe it or not this is a two story master closet.
#16 ·
It sounds interesting though and of course we will need pictures or it didn't happen. What part of the world are you in?
#23 ·
Only problem with anchorage ......Just using expansion anchors won't work........ The best way would be anchoring thru stairs with threaded rods and backing plates on other side........ A 1/2" wall square tube about 4" min. would hold with a 1/2" mounting plate would suffice for holding a tread........ Remember to have all plans / details reviewed by an engineer ......( structural).
#28 ·
What about substituting a 2" x 6" x 1/4" tube for the 5" plate? Also use all thread through the block with a long flat plate instead of individual backing plates. That many wedge anchors guarantees that at least one will hit a week spot, not to mention with time they will pop the face right off the block.
Sent from my XT1045 using Tapatalk
#29 · (Edited)
I like your ideas, but think you should talk with a professional stair builder or architect in your area. I built stairs exclusively for 30 years, mostly wood, only did a few with metal and wood. Here's one with wood metal and glass I built. Retired now, but still go to the shop everyday and love it, my son runs it, he's be working with me for the last 20+ years.
