It's maddening sometimes trying to find what square tubing fits inside other square tubing. For example, I have an application where I need 3/4 Sq. 11 wall gauge to fit inside 1" sq.
11 gauge which I have plenty of, won't work because it is too tight because of the inside weld on the tubing and the application is to long to try to sand the weld down. 12 gauge wall would be perfect but I don't believe local steel yard carries it in stock. I am probably stuck with 14 gauge and a sloppy fit.
Any tables you gents are aware of that give sliding fits for square tubing and pipe for that matter, I am always screwing around trying to figure that also.
