Hello All, I'm new to the forum, and wanted to put in my first post.
I've gone through the threads pertaining to the HF mig welder performance mods, and have some questions regarding possible mods to my new Chicago Electric mig 180 and mig 90, (the "black" boxes)
Regarding the mig 180;
So far I'm happy with the 180's performance, except for the wire feed and torch length. The feed seems underpowered and "choppy", (unless the torch is laid out almost perfectly straight.)
The torch length is also ridiculously short at 6 ft.
Is there anyway of increasing the power/performance of the drive system?
I've read posts about doing the full 100,000uf cap/resistor mod to similar units to increase power, and at the same time, adding a cap and rectifier on the feed motor. Is the mod to the feed motor done as a necessity because adding the larger 100,000uf cap affects the drive? If I'm happy with output performance, can I skip doing the big cap mod and only do the modifications to the feed motor? Or do they go together?
Since the drive assy/motor seems to be one sealed unit, it doesn't appear that I can just remove and upgrade the drive motor?
Also, against my better judgement, I ordered a new 10ft torch to swap with the 6ft one. I'm definitely afraid, (and unfortunately, pretty confident) that the drive performance will be even worse.
Does anyone have any ideas?
____________________________
Regarding the mig 90;
Can I do a cap mod to this machine to increase output performance? (I use it only for flux core welding).
If so, what size cap would I use?
(If I know what I'm doing, attached should be the schematics for both machines. The first one shown should be the 90, the other is the 180).
Any help would certainly be appreciated. Thanks in advance.
