new Everlast 210EXT won't start arc (AC TIG)
6.9K views 25 replies 13 participants last post by  kjemison1966
#1 · (Edited)
I'm puzzled. Last time it worked fine. Today on the same programmed settings it won't start an arc.
Its intermittent too.
I'll try starting an arc right on the groundclamp, and sometimes only HF and other times a full arc, but about 8 times of 10 no arc at all.
Sometimes the relay clicks, sometimes not at all.
And the relay clicking .... doesn't necessarily do anything. I'm using the 'new' NOVA pedal.
I'm pretty new to this machine (and all TIG) this pic shows about where I'm at in skill level.
I should be able to make this work.
Any ideas what to look for?
#7 · (Edited)
The tungsten was NOT cleaned and dressed. If this was it I'll eat my hat. Are you serious? I can't imagine a tungsten in any condition (other than non-existant) refusing to pass amps.
Wrong place to ask. There is an Everlast forum down the ladder.
I looked all over for an Everlast forum on WeldingWeb, can't believe I didn't see it. Was the middle of the day and i was frustrated.
OK NOW it's posted in the Everlast forum: http://weldingweb.com/showthread.ph...d.php?701682-new-Everlast-210EXT-won-t-start-arc-(AC-TIG)&p=8633269#post8633269
#16 ·
I'd read the manual with regard to the setting and checking of the points gap.
also get a meter and check if the main contactor / relay is switching
How new is it ?
That would make me nervous if it can't even make it a short time.
Perhaps the refund is the smart move.
I'd be wary of shipping it back for service if you have to pay shipping yourself.
#18 ·
If you read the manual, then you might notice you have the torch in the + instead of the negative. It should always be in the negative. No where in the manual does it say it should be in the positive for TIG.
#19 ·
Wrong user for that. The OP is having starting problems. It was Bob92553 that had it hooked up wrong. He figured it out apparantly.
The OP is dissecting his brand new machine looking for a defect.
#20 ·
J. Akuhead has the torch on Positive. That's the one I am referring to. The torch depicted in the picture if you look carefully, is in the positive, and not the negative. Most likely he was welding stick at some point, or removed his torches and reconnected it wrong, forgetting to move it back to the negative torch. That will cause starting issues. This, unfortunately is common. Somewhere as a recent development, I've had a bunch of customers putting it in + for AC. I've had in the past, many people just startby putting it in the positive for AC and DC, saying they hook the "ground" to negative because that is the ground. I have to work with them to understand it isn't a ground but a work clamp in the truest sense of the word. It merely completes the circuit path. I haven't found the source of recent misinformation about changing to AC yet, but this is a fairly recent issue with a lot of people saying the "internet" said to put it on positive for AC. Not sure where that bit of information is found or occurring.
#21 ·
Good eye! Now I am trying to figure out what the AC arc start sequence would look like. Does reversing the polarity affect the balance on start. Could be. It should try to start, but then maybe it goes into default shutdown, IDK. Hmmm.
#22 ·
Keep in mind that the HF has to flow through things like the table and through rust or scale and then to the work and to the tungsten when polarity is reversed. Polarity would affect the balance at the start depending upon how the unit was designed to start, whether on + or -. IIRC our's are designed to start on -. I'd have to double check that, but seems right from memory.
#24 ·
Hmm... I have had my share of poor support from the Blue company.... Spent close to 6K on a new Synchrowave 250 TIG Runner DX .... Was kept in a clean environment and used 99% of the time on Aluminum.. I had approximately 150 hours of welding time on the machine. One day I turned it on, it displayed an error code. Shut it down and fired it back up.. code gone... made 2 welds and POP! ... Shut it down (obviously) ... I could smell the proverbial electric odor in the air, called Miller, worked with a tech for over an hour and they said it blew out a main board (not sure what the correct name of the board is) ... Anyway, I said is this covered under my warranty... he checked and said I was out of warranty by 2 weeks.. Ok,... "how much is the board?"... he says a around $1400 .... Hmmm... I told him that this machine has very low hours on it, it was not in a production environment and could he please work with me on the warranty... nope and that was the end of that. $6000.00 on a machine, around 150 hours of use maybe... and it eats up a $1400 circuit board...
So, now I have a Everlast PowerTIG 200DV ... I use it primarily for it's TIG functions.. I have $1200.00 tied up in this machine.. It works great! .. If I get 3 years out of it and it goes up in smoke, I am still way ahead of my old Blue machine that I had for 3 years and 2 weeks :) ...
BTW I think I read somewhere that all machines are basically made in China now... Not sure if this is true ... anyone know for sure?
Have a great Sunday!
#25 ·
This. A lot of our converts to Everlast are because of this very reason. People pretend it doesn't happen. I hear this story regularly when I talk to customers. The point is, that there are gaps in any warranty system, particularly when it expires. :rolleyes: But the cost of part replacement is the kicker. People often leave that fact out when they talk about anything but blue or red. Then you could have the same thing or different part go out and you are out of all that money again.
#26 ·
Mr. Lugweld, you were the one that helped me fix my Supercut 51P .. you were more than patient (spent about 30 min on the phone troubleshooting)... figured out that I made the mistake of applying too much input pressure on the regulator (notice ... "I" made the mistake... I was in a hurry to play with the machine and did not read the manual thouroghly!.. it was not the products fault!)... purchased a new regulator, it arrived in a few days and the machine works as advertised! ... With that being said, I was on hold for maybe 2 minutes waiting for you. In my book, that is very good service and support!
Thanks again for helping and I am looking at one of your MIG machines (Power I-MIG 200E) ... It will be an asset to my little shop!
