Well I see a lot of people on these forums write reviews of their machines and I think there very helpful so I figured I would write one up as well. First off I am a professional welder with to many certifications to list and ive welded and formed almost any material you can think of. Im a shear and brake operator, and a sheet metal layout specialist, I take great pride in my work, any job worth doing is worth doing right. Blah blah blah Ive know how to weld..... anyway.
I wanted a machine for use at home to build and repair frequent small projects for friends or stuff I come across but I also wanted a machine that had that extra little umph, for when I come across those big projects that I occasionally get. I was very particular about the features and capabilities of what I wanted in a machine. I wanted a TIG/stick that would do AC/DC and and have at-least 250 amps. Believe me I would have loved to have gotten a Miller Dynasty 350 combo but it just wasn't feasible, price wise for what I need. so I did my research and really started looking into the Everlast stuff. After a few eMails and phone calls I had my mind made up. The people at Everlast were very helpful.
So I recently took delivery of the powertig 250 EX and water cooler combo. I was attracted to the unit for price and capabilities, It can Tig AC-DC @ 250 amps with a 60% duty cycle and stick @ 200 amps with 35% duty cycle and its an inverter witch is great for wiring at home and for portability on the go. The front panel of the welder is great, I personally like being able to see all my dials and knobs instead of having to work with a digital interface. I have had a couple of days welding with the machine and it lays down just as good of a bead as any welder ive ever used and I have used a lot of different machines. The AC frequency and balance work great, you can dial up an aluminum puddle to perfection. Same goes with DC it has an arc force dial that is similar to "Dig" on other machines and it works great, the machine also came with a pulser that is usually only seen on higher end tig machine models and the one on this machine has more adjustment and range than any I have ever used before. The machine just straight up welds great.
However with every great deal comes a couple of shortcuts, and in all honesty these are pretty minor (I'm just a picky SOB).
-I don't like the hose clamps for the hose ends, I think it looks cheap. I would have paid extra money to see nice clean crimped hose ends.
-I have never seen a flow meter with a male fitting. Every spare inert gas hose I own or have ever used or seen for that matter has a male CGA swivel fitting crimped on each end.
-The gas inlet on the back of the machine is a hose barb. Why not the standard female CGA fitting that is on every other machine. Like I said I don't like hose clamps.
-The flow meter reads in LPH instead of CFH, this is extremely minor and shows just how picky I am. I don't like the cheap looking clear, (water) gas hose.
-Every water cooled tig torch I have ever used has a male RH thread CGA fitting for the gas and the water lines are male LH CGA fittings the power connection may differ but those have always stayed the same, if you guys could have stuck with that than torch interchangeability would have been a cinch.
-The quick connect gas line is a fitting I have never seen. its quick, but where can i get another one to fit to my other torches, and I dont want to cut my old torch ends off to just accommodate this machine because I use them for other machines as-well.
-The water cooler works great but the fittings are different from every tig cooler in the world.
-The lift arc only works with the press of the torch button or the pedal. That kinda defeats the purpose of lift or scratch start. I have worked on massive boats for friends and i dont want to drag a foot pedal around, and if I dont have the supplied torch on the machine or if I need a small flex-head it wont work unless I get someone to step on the pedal for me.
-The pedal.... The pedal is huge, it has very fine control but has a tendency to want to flip forward well fully depressed.
Like I said I'm picky and a lot of this stuff can be fixed with adapters, a lot of adapters, but that requires more ugly and cheap looking hose clamps or I could pay a little more and crimp everything.
Overall this is a great machine it functions extremely well and does what it is supposed to do. I am extremely pleased with the purchase and am already looking to purchase a plasma cutter. I think Everlast has a really good thing going and information or constructive criticism like this will only help build the company bigger. Thank-you
