Hi
I am santosh and work on Power plant construction. Recently we have found some problems with P22 weld spool supplied by one of the supplier. Following are the details.
Base metal is ASME SA 335 P22. Pipe size is 4 inch sch 80 and used in boiler. Design pressure and temp is 130 bar and 450 degree centigrade respectively. There are pipe to pipe butt welds which have been done by GTAW process. As per code and WPS filler metal to be used is E90S-B3.
When we performed PMI on weld joints we are finding weld composition of P11,P5,P22 and P91 grade. It looks like there is clearcut mix up of filler rods. It looks like fabricator has used ER80S-B2 (Equivalent of P11) and ER80S-B6 (Equivalent of P5) filler rods for welding ASME SA 335 P22 pipes. Since the tensile properties of the filler rods are more than base metal,can we keep those welds as its is ? Does code permit to useER80S-B2 (Equivalent of P11 ) or ER80S-B6 (Equivalent of P5) to weld P22 pipes ? Will these welds sufficiently strong in longer run ?
what will be long term behavior of welds if we use ER90S-B9 (Equivalent of p91) to weld P22 pipes ? Are their any chances of these welds cracking during operations ?
